Deere/Yanmar 650 - Trying to Raise From the Grave
   / Deere/Yanmar 650 - Trying to Raise From the Grave #21
Is the pump timing established mechanically with shims? It is on the 950 but I don’t know about yours. When reinstalling the old pump you can usually get away with using the old shims but if installing a mew pump I would time according to the manual.
It is. I bought 2 new shims. Hopefully will be able to get this running in the next week or 2.
   / Deere/Yanmar 650 - Trying to Raise From the Grave #23
The shim kit usually includes shims of different thickness. Basically (as I remember) you want the number one port to start flowing at the start of injection mark on the crank. Probably better review the procedure for your machine. Also needed a test line to attach to that injection port.
2012 Cadillac SRX SUV (A55758)
2012 Cadillac SRX...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A54607)
2006 KENWORTH T800...
2018 JLG T500J ELECTRIC PORTABLE MANLIFT (A52705)
2018 JLG T500J...
UNUSED RAYTREE RMLS18T HYD LOG SPLITTER (A54757)
UNUSED RAYTREE...
(APPROX 10 PCS) 2" X 6" UP TO 10" TUBING (A54756)
(APPROX 10 PCS) 2"...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
