Deere x595 Curtis Cab question
   / Deere x595 Curtis Cab question #1
jimsgt
I purchased a 2003 Deere X595 this fall, and it came with a Curtis cab. The model numbers for the cab are BM21481 and BM21482...yup, it lists both on the tag. My question is in regards to the approx 2" gap between the hood and the cab above the floorboards, where your shins would be. I think I attached a pic of the gap (and an action shot of the whole machine...just because :)). The gap is a little larger then it appears in the picture. Does anyone else have this cab on a similar machine, and am I missing some parts that would normally fill this gap? I'm not above cutting some sheet metal to fit, but wanted to see what the factory intended.
Also, would anyone happen to have a manual for this Curtis Cab? I checked their website and even called Curtis. They told me they don't keep anything for a unit that old. Seeing as it's the newest tractor in my barn by 34 years...and also newer than my truck, I did my best not to get offended. The Deere dealer was much more helpful, but still couldn't come up with a manual. I'd appreciate any help anyone could give in directing me towards a manual for the cab.
Thank you,
Jim
   / Deere x595 Curtis Cab question #2
Here are a couple pics out of the manual showing your gap, and then the interior trim piece that
is supposed to cover it . they are nice cabs, but not airtight by any means....
   / Deere x595 Curtis Cab question #3
I think I'd try some foam pipe insulation, as I assume the gap is to allow the hood to be opened.
But looks like a nice cab, just not able to remove your boots and go barefoot while blowing snow.. :D
   / Deere x595 Curtis Cab question #4
If you want pdf of the install instruction pm me and I should be able to email it.
Thank you Dutch 445, beenthere and MorrisonSteel! The X595 is a great machine, and what a difference the cab makes, can't imagine going back to snowblowing without one! I PM'd Dutch 445 re: his offer to e-mail the manual, as it was the first I saw, but I appreciate all of your help and your speedy responses. One step closer to barefoot snowblowing...
Jim
   / Deere x595 Curtis Cab question #6
Dutch445, I just purchased a used cab for my X585. Would you be able to forward me a copy of the manual where you got the pictures from? I also see where Morrisonstell had them to in pdf format as well. Anyone that can send me a pdf copy of the manual/installation instructions it would be greatly appreciated!
Thanks!
Jesse
Thanks!
Jesse
Hi Jesse,
If you could pm me with an e-mail address, I'd be happy to forward the info Dutch sent to me.
Thanks,
Jim
   / Deere x595 Curtis Cab question #8
Hello,
I recently purchased a used BM21481 on ebay that supposedly fits a JDx720.
If anyone has a copy of the parts/instruction manual for it, I would greatly appreciate.
Thanks,
Dale
   / Deere x595 Curtis Cab question #9
Send a PM to Morrisonsteel who posted above 4 years ago, and see if you can connect with a manual. You might get lucky.. :)
Also, view the "similar threads" below to see if any give you some ideas.
:welcome: to TBN
Hi Dale, I tried attaching a PDF of the manual to a PM for you, but couldn’t get it to work. If you’d like to PM me an e-mail address, I’d be glad to pass along the PDF of the manual Dutch was kind enough to send to me. Still very happy with my x595 and cab! Thanks, Jim
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
KUBOTA RTVX900 (A51243)
KUBOTA RTVX900...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
3 pt Aer-Way (A50514)
UNUSED TOPCAT SSSG72 HYD QUICK ATTACH GRADER BLADE (A51244)
UNUSED TOPCAT...
2015 Nissan Sentra S (A50324)
2015 Nissan Sentra...
