Forks deere worksite pro pallet forks question
   / deere worksite pro pallet forks question #1
disney
orlando fl
scag turf tiger 61" #2, gx95, sold f525 twice, f725 sold
hello. does anyone have or know if the deere worksite pro pallet forks use standard ita class II (16 inch hook spacing) forklift forks? or do all major brand skid steer pallet forks use standard forklift forks/tines? thanks in advance for any responses, and please have a safe and happy holiday everyone.
   / deere worksite pro pallet forks question #2
Not sure what information you are looking for but I have a set of the 48" rail pallet forks from Work Site Pro if you need some measurements.
hello. good morning. the 'B' height should be the easiest to get as you should be able to measure the outside of the rails. If it is easy to get the 'h1' distance (without taking off a fork... its not worth the effort) that would be great also. thanks a lot:thumbsup: btw I got the service manual for the 110 if you ever need anything. :)
   / deere worksite pro pallet forks question #4
I will see about the measurements for you this morning and post back. Couple of hours behind you as it is still dark this morning.
If you have them, are you happy with them, or do you wish you bought a different brand? how have they held up?
   / deere worksite pro pallet forks question #6
disney,
The rails are spaced 16 inches apart outside to outside, The inside to inside measurement of the upper and lower hooks (B) is about 16 5/8 inches the rear of the hooks are almost 7/8" long. That would appear to be h1 for 14 7/8". It appears to me when fully hooked on the upper rail that the lower hook only has about 1/4" holding it in place.
I bought these pallet forks with the 110 in Jan. of 2005 and have had zero problems with them as I would expect since this ian't a complex tool. Heres some pictures and also an add on scaffold attachment that attaches to the forks for higher work. When I built the scaffold attachment I also made a top handrail that can socket on top if you are using the top scaffold position but don't have pictures on this computer.
   / deere worksite pro pallet forks question #7
I believe most skid steer forks are class 2.
2017 FREIGHTLINER M2 106 (A58214)
2017 FREIGHTLINER...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52707)
(INOP) 2016...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2018 Deere 323E (A53317)
2018 Deere 323E...
2016 Ford F-150 Single Cab Pickup Truck (A55973)
2016 Ford F-150...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
