Forks deere worksite pro pallet forks question
   / deere worksite pro pallet forks question #1
disney
orlando fl
scag turf tiger 61" #2, gx95, sold f525 twice, f725 sold
hello. does anyone have or know if the deere worksite pro pallet forks use standard ita class II (16 inch hook spacing) forklift forks? or do all major brand skid steer pallet forks use standard forklift forks/tines? thanks in advance for any responses, and please have a safe and happy holiday everyone.
   / deere worksite pro pallet forks question #2
Not sure what information you are looking for but I have a set of the 48" rail pallet forks from Work Site Pro if you need some measurements.
hello. good morning. the 'B' height should be the easiest to get as you should be able to measure the outside of the rails. If it is easy to get the 'h1' distance (without taking off a fork... its not worth the effort) that would be great also. thanks a lot:thumbsup: btw I got the service manual for the 110 if you ever need anything. :)
   / deere worksite pro pallet forks question #4
I will see about the measurements for you this morning and post back. Couple of hours behind you as it is still dark this morning.
If you have them, are you happy with them, or do you wish you bought a different brand? how have they held up?
   / deere worksite pro pallet forks question #6
disney,
The rails are spaced 16 inches apart outside to outside, The inside to inside measurement of the upper and lower hooks (B) is about 16 5/8 inches the rear of the hooks are almost 7/8" long. That would appear to be h1 for 14 7/8". It appears to me when fully hooked on the upper rail that the lower hook only has about 1/4" holding it in place.
I bought these pallet forks with the 110 in Jan. of 2005 and have had zero problems with them as I would expect since this ian't a complex tool. Heres some pictures and also an add on scaffold attachment that attaches to the forks for higher work. When I built the scaffold attachment I also made a top handrail that can socket on top if you are using the top scaffold position but don't have pictures on this computer.
   / deere worksite pro pallet forks question #7
I believe most skid steer forks are class 2.
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2014 Chevrolet...
2022 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
2007 Capacity TJ6500T Trailer Jockey Truck (A55973)
2007 Capacity...
1997 Generac T/A Towable 175kW Diesel Generator (A56857)
1997 Generac T/A...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
