DEERE GRILLE GUARD?
/ DEERE GRILLE GUARD? #1
dirtworksequip
Wheeling, WV
2006 JD 3520 w/cab & 300CX loader. 1995 JD 870 w/440 loader & 8b backhoe.JD 455 w/54" mower deck.
Does anyone know if a grille guard that fits the 3x20 series will fit on 2210 tractor? Thanks!
Sincerely, Dirt
/ DEERE GRILLE GUARD? #2
I don't have a clue, but if you want I can send some measurements. Just tell me what you need.
/ DEERE GRILLE GUARD? #3
Whoops sorry, I was a little dyslexic there. I read your question as 2x30 series instead of 3x20. Come to think of it, 2x30 doesn't work for my tractor either. Oh well, another senior moment.:mad:
/ DEERE GRILLE GUARD? #4
Sincerely, Dirt
Wouldn't if be a bit big if it bolted up?
BigD, if you could...........measure your frame just behind the bumper. The 3x20 are right around 10.5 inches outside to outside. The only reason I am asking is I am selling my grille guard off my 3520 on eBay and one of the potential bidders wants to know if it will fit his 2210. Thanks.
Nuru, not sure about how wide it would be in proportion to the tractor. Maybe it is too wide.
Sincerely, Dirt
/ DEERE GRILLE GUARD? #6
Dirt; I was thinking it was as the grille gaurd for my 4310 is a lot larger than the one for my 4100 was - the 4310 is wider by a bit.
/ DEERE GRILLE GUARD? #7
Dirt, I'll measure it tomorrow after I change out of my "Sunday go to church" clothing and back into my play clothes. However, I'm not sure it will help you. My understanding is the 2210 is a lot like the 2305. The 2320 has a different frame. I'll send the measurements along anyway.
Nuru and BigD9, thanks for the input on the grille guard.
Dincerely, Dirt
/ DEERE GRILLE GUARD? #9
Dincerely, Dirt
Here are some pics of my 4310's grille guard. I took a couple with the tape measure visible/
The inside of the grille guard is approximately 19 and 1/16 wide, side to side, whereas the overall width of the guard and mounting brackets is ~20 and 1/2 inches.
the 4310 rfame is 11.5 inches end to end (outside to outside). I would think the 2210 frame is slimmer.
/ DEERE GRILLE GUARD? #10
Dirt, first let me apologies for not getting back to you with those measurements last Sunday. We had a pot luck after mass and.... well the doctor said it was probably food poisoning. The way I felt I think I must have died! :eek: I'm just now getting back to feeling good.
I know you wanted measurements. Do you still need them?
Again, I'm sorry
BigD, nah..........don't worry about getting the measurements. Take care and thanks anyhow.
Sincerely, Dirt
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
2018 Kenworth T680 (A64127)
2018 Kenworth T680...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
