I own two Bush Hog 307 rotary cutters that I use to mow fields and brush and I am very pleased with the quality of their cut. I recently purchased a John Deere 709 rotary cutter because I thought the balloon tires would be good on soils that might be a little wet. I cannot get a good cut with the Deere 709. It came with a factory stump pan on the shaft and I put on brand new blades. It doesn't seem to lift the grass very well and knocks the grass down as much as it cuts it. It also seems like at it's lowest setting, with the housing almost touching the ground, that the cut isn't very short.
I've looked at the JD parts breakdown for the 709. There are several different configurations. Some feature dual blades stacked on top of each other, one of the blades is called a suction blade. But there is only one style with a stump pan and is only compatible with single blades. Maybe they offer the suction option because the standard set-up works so poorly. I don't know.
I've looked up the tip speed on both machines and the Deere actually seems higher. I am at a loss. The cut is so bad that I thought the blades may be installed backwards, but that is not the case. The machine is nearly new. Does anyone have experience getting a good cut with the Deere 709?
