deere 445 runs rough
/ deere 445 runs rough #1
tonyd6383
john deere 445
hello i just bought 98 john deere 445 it was not runnig whn i bought it i just got it to run but its rough i clean out the throtle body and cleaned the fuel injector ,fresh gas and plugs any thing else i can try thanks
/ deere 445 runs rough #2
:welcome:
No good ideas. Have you checked the compression? Checked/replaced the fuel filter?
hello yes i have also check the fuel presure and that was fine , i talked to a mecanic today and he said if the temp gage is not working that could be 1 problem ,because the temp sendind unit works with the manifold air sensor . witch both parts will set the right fuel and air. i called j d and its over 300 for the parts . iam willing to try it
/ deere 445 runs rough #4
Which parts are you going to replace?
iam going to replace the temp sending unit ant the manifold air sensor
/ deere 445 runs rough #7
have you checked fuel injection wiring harness? They tend to get brittle, brake, fragile and will intermitt signal to injectors!
2013 Ford F-250 Pickup Truck (A59230)
2013 Ford F-250...
Crown RC5535-35 Stand-On Electric Forklift (A59228)
Crown RC5535-35...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
International 9200 (A61307)
International 9200...
1629 (A57192)
1629 (A57192)
2019 Bomag BW 211D-5 Single Drum Vibratory Soil Compactor (A59228)
2019 Bomag BW...
