Deere 4310 transmission controller problems
   / Deere 4310 transmission controller problems #1
todd 4440
marble hill mo
john deeere
i am working on a 4310 i have replaced the transmissin controller it is a e-hydro with cruise control, the controller is sending 2.38 volts out of wire F-3 for the flywheel spd. sensor so I cut the wire in case of a feedback and the controller is still sending the same voltage. I have all my grounds they are good and clean, correct supply voltage, and the cruise, load match, and motion match switches are also operating correctly. I cant calibrate the controller with this problem the status ind. light is on steady. NEED HELP thank you
   / Deere 4310 transmission controller problems #2
I moved your post to the John Deere Owning and operating forum. You should get a better response here than in the "News and Feedback" forum.
Aaron Z
   / Deere 4310 transmission controller problems #3
Todd, I don't know the answer, but I have a PDF of the tech manual you're welcome to if needed
Joe
shoot me your email if so
   / Deere 4310 transmission controller problems #4
Without knowing why you replaced the controller, I would guess the flywheel speed sensor is bad. There had been a few posts of bad flywheel sensors and at least one of the posters replaced his controller multiple times and turned out to be flywheel sensor.
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
13042tx (A55973)
13042tx (A55973)
PumpJack Brand Pump Jack (A56436)
PumpJack Brand...
2015 MACK CXU613 TANDEM AXLE SLEEPER TRUCK (A59575)
2015 MACK CXU613...
Pickup Truck (A59230)
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
