Deere 4210: PTO off-seat operation doesn't work.
   / Deere 4210: PTO off-seat operation doesn't work. #11
I have a 4320, the next series of compact tractor after the 10 series. I can operate the rear PTO while off the seat doing all of the above steps. What I see missing is is selecting the rear pto only. I have a mid pto and a rear pto. I have either the rear pto alone with the selector lever and or both the mid and rear pto again with the selector lever. When the selector lever is in the both position the off seat, operation of the pto's will not work. It only works when I select the rear pto separately. Later
   / Deere 4210: PTO off-seat operation doesn't work. #12
Just for info on the above, I do not need to put the hydo transmission in netural to make the off seat pto engage.
It's relatively new, but i've done a ton of work on it.
   / Deere 4210: PTO off-seat operation doesn't work. #14
I went thru your green tractor posts. I think you could easily get a John Deere technicians job. Great work.
Hey thanks! It's a fun time :)
Btw, fixed it. Here is the thread.
Adams 5T Pull-Type Fertilizer Spreader (A56436)
Adams 5T Pull-Type...
2001 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W41X143155 (A57453)
2001 Ford Crown...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
2017 FREIGHTLINER M2 106 (A58214)
2017 FREIGHTLINER...
2011 Kenworth T700 T/A Sleeper Cab Truck Tractor (A55973)
2011 Kenworth T700...
2014 REMOLQUES DEL NORTE 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 REMOLQUES DEL...
