Deere 4200 HSt
   / Deere 4200 HSt #1
Mac248
JD 4200
I have a 2000 4200 and as of late the tractor will just die while using it then it will start right up. It happened to me 6 times today while mowing a large field. Could it be the seat safety switch even though I dont come off the seat? or is it maybe the htermistor I have read about.
Thank You
   / Deere 4200 HSt #2
If thermistor is bad, tractor will not start. Seat safety switch is a possibility. Perhaps it's disengaging as you bounce across the field? It isn't difficult to access, unplug and jumper that switch.
   / Deere 4200 HSt
OK thanks I was leaning the way of the seat switch but read about the thermistor and thought I would ask.
   / Deere 4200 HSt #4
Un-connect the connector near the seat switch and slide in a shunt (short wire in U-shape) to let the electronics think the switch is closed.
   / Deere 4200 HSt
Thanks I will do that.
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
2012 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
Harper TV130 High Dump Turf Vacuum Sweeper (A59228)
Harper TV130 High...
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
2013 Ram 1500 Crew Cab Pickup Truck (A59230)
2013 Ram 1500 Crew...
Bush Hog Rotary Brush Cutter (A59228)
Bush Hog Rotary...
