Deere 3203 Flashers
   / Deere 3203 Flashers #1
LBA1999
John Deere 3203
I have a 2006 3203 with close to 400 hours on it. My son left the factory warning flashers on until the battery was dead. After charging the battery, the flashers will not work and the hour meter is out. I looked at the parts diagram and talked to my local dealer mechanic. There is no listing for a flasher module in the parts diagram. Ideas?
   / Deere 3203 Flashers #2
Did you check all your fuses?
   / Deere 3203 Flashers #3
they're usually made into the headlamp switch
We checked all of the fuses twice. The headlamps and work lights work fine. It has a left/right turn signal switch also. Any idea how it relates to hour meter going out?
Thanks! That is more than I have seen anywhere! I will dig into my tractor this afternoon. I see the diode listed with the Wiring harness for my tractor, but no picture. The post you referred me to will really help.
   / Deere 3203 Flashers #7
In my case, the hazard and directional lights stopped working. I don't think my hour meter stopped working, but I'm not sure.
Good luck, let us know when you get it fixed.
   / Deere 3203 Flashers #8
Were you able to locate problem, I am working with a friend with similar problem.
   / Deere 3203 Flashers #9
Al
:welcome: to TBN
The original poster hasn't been active for about 7 years, so you may "wake him up" by sending a PM which will go to his email.
His solution would be interesting to know for this thread.
Click his user name and there will be a place to PM. Otherwise, another member may jump in to help..
What have you been able to decipher thus far?
I presume you already read the linked thread mentioned by "chipsndust"
https://www.tractorbynet.com/forums...305-diode-replacement-hazard-directional.html
2020 INTERNATIONAL LT625 SLEEPER TRUCK (A53426)
2020 INTERNATIONAL...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
2006 Hummer H3 4x4 SUV (A51694)
2006 Hummer H3 4x4...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
