Deere 148 lift cylinder
   / Deere 148 lift cylinder #1
joeu235
Platinum Member
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
Does anyone know how to get this cylinder head off? Turning the head does nothing. Deere 148 lift cylinder. Please help.
   / Deere 148 lift cylinder #2
So does the head not spin? Or it spins but doesn’t unthread.
Yes, spins but does not unthread
   / Deere 148 lift cylinder #4
Use hydraulic pressure or air pressure to extend the rod so the piston puts pressure un the gland. Use a spanner wrench or hammer & punch to unthread the nut from the gland. You need enough pressure on the piston to hold the gland from rotating. When the nut is off, drive the gland down into the barrel enough to retrieve the snap ring from the I.D. Of the barrel. Then remove the rod, piston, gland and nut from the barrel.
Thanks!! It took some heat to soften some red locktite but the air method worked.
Seems to me some JD engineer got bored one day and designed the most complicated head he could imagine.
   / Deere 148 lift cylinder #6
That cylinder rod guide is very simple compared to some of the complicated JD steering valves & SCV's that the JD engineers came up with!!!
UNUSED CFG INDUSTRIAL SSECAG-Y HYD AUGER (A51248)
UNUSED CFG...
RYOBI 18V ELECTRIC 13" PUSH LAWN MOWER (A51248)
RYOBI 18V ELECTRIC...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED GOLD MOUNTAIN M122009 12'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
UNUSED AGT 32-743 60" HYD GRAPPLE (A51248)
UNUSED AGT 32-743...
