Deere 110 TLB help
/ Deere 110 TLB help #1
crimedog325
woodbury, Ct
JD 110TLB
Just bought a new to me 2003 Deere 110 tlb. unfortunately its first use was to bury my pup. It worked great and had plenty of hydraulic power(fel and backhoe) . I have put about 10 hrs on it and it has been losing power pretty quickly. engine rpm seems fine 2300 and seems like it drives pretty well , which I believe is also run by main pump. Fluids all look good and filters less than a year old. Any ideas on what can cause this issue? I have checked linkages for binding and everything seems good. The three point hitch lever(rockshaft) is all the way forward and seems to be fully traveling,(when checked on the rear of the tractor). I know there is a switch that is supposed to deactivated the rockshaft when the backhoe is attached but I have noticed that it still moves. I am not sure if that can be an issue even though the lever is in the off position. Any ideas would be greatly appreciated. I was hoping to get more than two days use before having issues :(
/ Deere 110 TLB help #2
Sorry to hear about the issues. could you be more descriptive about losing power? the rockshaft should not move if the backhoe is on. If it moved far enough, I am sure it would catch on something, and likely would not be good. I know the switch is more prone to read backhoe attached (when it is off) then backhoe off (when it is actually on) but a wiring issue could give it the wrong reading. anyway from what I remember that switch directs a few gpm (from an aux pump) to either the 'hoe, or the hoe and loader, but it would only be like 10-20ish %
2014 Freightliner Bucket Truck (A63689)
2014 Freightliner...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
JCB 3TS-8T Compact Track Loader Skid Steer (A61572)
JCB 3TS-8T Compact...
2004 John Deere 8320 (A63688)
2004 John Deere...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
70in Rock Bucket Skid Steer Attachment (A61572)
70in Rock Bucket...
