deere 1050/ yanmar 336d same exact tractor? common issues?
   / deere 1050/ yanmar 336d same exact tractor? common issues? #1
johntom89
John Deere
somewhat recently i purchased a deere 1050 with a bit over 2000 hrs on it, motor was rebuilt by a well regarded mechanic around here, she runs great but has a few maintenance items i have to replace like the brakes, clutch in a couple years, and the front axles bearings.
my concern and questions surround that front axle i have done all the digging i can but theres simply nothing and no one with first hand knowledge. the stub shafts after you take the front wheels off have roughly 1/8" of play overall which i take as wheel bearing need replacing, but the "knuckle seal joint" area has about a 1/16" of play from side to side is this play within spec? should include the previous owner replaced the seal there, but its clear he did his best but doesnt have much experience. i may be wrong but i think there could be a missing wear sleeve or collar, is there one on an 88' model?
and better off safe that sorry i do intent of replacing the "wheel bearings" and new seals in those front lower gear cases. Is there supposed to be play between the stub shafts and the surrounding lower gear case? or is it similar to my sierra as a good and new set of bearings are rock solid tight?
i know this is 99 questions, but to help with very small engine oil weeps can i add a quality stop leak like lucas? and a piston on the backhoe boom is weeping and a quick connect, can i add the blue devil hydraulic oil stop leak and be safe?
and help, and input would be very much appreciated guys. :drink:
   / deere 1050/ yanmar 336d same exact tractor? common issues? #2
The 1050 and the 336 are not identical but they do share most of the same front axle parts and a few other parts. The front axle should not have nearly that much (if any) play. All of those gears need to mesh correctly and consistently and that is not possible with that much movement. There is a good writeup on replacing those seals below which also shows the gears & bearings
YM336D YM311�D Front Axle Seal Replacement - Yanmar Tractor Support Message Board
thats is the exact clarification i needed hoyetractor!! i really appreciate it. there is nothing quite like getting the exact help you really need to bump you into the direction when youre really not sure :cool2:
that link is how i plan on tearing into it, and my parts will be coming from you. i was actually watching a clutch replacement video for yanmars yesterday with my father that Hoye has, much smaller tractor but a good guide and proof of concept.
i really appreciate everyone taking their own time and answering thank you very much
i will be replacing the hydraulic piston seals maybe next year if i can safely get by, anyone try the "blue devil hydraulic seal sealant"? it sounds like the ticket i am looking for to simply buy time, but if it hardens like super glue when cold or some other huge issue then i have to bite that bullet aswell
   / deere 1050/ yanmar 336d same exact tractor? common issues? #4
I'm happy to help and we appreciate the business.
I, personally, haven't ever used that sealant but I know a lot of people have had good luck with similar stuff if the leaks are caused by dry seals. It probably won't fix the leak at the quick connect but some new orings or some teflon thread sealant (depending on where it is leaking) should.
aaron from hoye, i really hope you get this message sooner rather than later as i need your help enormously again sir
i am 45minutes into ordering my dam parts for the tracotr (i dont have any manuals or schematics yet and im more of a hands on wrencher but still have enough patience for this stuff)
my deere is a 1988 1050 4wd as im sure you already know, and i am honored to have to answer my post yourself and you are the missing link in my dilemma here. what are the part numbers i need to completely rebuilt that lower spindle housing? i read that great write up from the guy in Pennsylvania but lack the necessary part #'s
cant figure out the sleeve there, then the brass ring on the inside of that lower housing?
also i need to replace the "wheel bearings" as that stub shaft has a pathetic amount of play (about an 1/8th slightly more)
i know i am throwing a load on you man, but i really do need your experience and your first hand know how
what are the bearings, seals, and/or bushings i will need to pick up to eliminate this slop for the years to come in that i genuinely am relying heavily on this tractor for
any help from you like this is a massive amount of good karma ( and a bit of business) i know youre a good man from helping me before here, and the only one i know who i can trust in this instance
thank you for any help at all man
   / deere 1050/ yanmar 336d same exact tractor? common issues? #6
Aaron is real good about responding to 'Contact Us' on his website. It may be random luck whether he reads this post timely.
   / deere 1050/ yanmar 336d same exact tractor? common issues? #7
Sorry for the delay. I was out of town this weekend. I'm happy to help but I'm sure there are lots of other trustworthy folks on here too. :)
It sounds like you have the 'new style' axle with the wear collars & sleeve? Is that correct?
4WD EXTERNAL ^: Yanmar Tractor Parts
[edit - I answered from my personal TBN account by mistake but it is still me! :). I'd make a terrible superhero. Alternate identities are too hard to keep track of! :) ]
Aaron i apologize for being a pain in the ***** :drink:
but hot **** the help is what i was hoping for haha i did see that on your main site there to be honest, i just wasnt 100% positive if things crossed over or if they were completely unique.
so the "wheel bearing are the same if it is the old style or new style?
and just so i know on the other front good sir, if i was to order parts that turn out unnecessary and obviously do not open them and keep them clean can i return them?
another huge thank you, with a huge reassurance for me and any one to view this post in the coming years you are the correct person/to get the parts for these tractors. they may be "most reliable" Deere ever had, but whether you like it or not you still have to take care of them and replace the parts that need replacing, making the relationship between us the community and you (the man for parts)
edit. also are there any notorious parts that like to wing off to never find it again land like a snap ring i will have to remove/replace when replacing the wheel bearings that youre aware of?
wow, how modern american can i get?
embarrassing i can tell you that lol
you answer many questions even with your simple listing of the parts, i read to the bottom after i posted. i see the part now that the parts can be returned
anyways, keep kick tail man. i know im going to be needed ALOT more from you, im just trying to work from most important down to my person nit-picking
i looked at the spindle you guys sell, i read your notes at the bottom about the front loader basically destroying the early ones so yanmar upgraded them twice. assuming mine being an 88' mine would be the upgraded-upgrade one? still not massive overkill as the rest of the tractor is, yet just good enough to be good?
   / deere 1050/ yanmar 336d same exact tractor? common issues? #12
I'm happy to help in any way I can. I'm not sure what version you would have but you should be fine as long as you take it easy with the loader work. Just keep it in the back of your mind that those front axles are not indestructible and bouncing around with a full bucket can cause problems.
   / deere 1050/ yanmar 336d same exact tractor? common issues? #13
I have a Yanmar 336D tractor, similar to the JD 950. "Similar" to the 1050 but no turbo charger. The front axles on mine broke. I replaced them with the heaviest Yanmar later edition units. I have had no problems since but I do not know if such units are available any more. I got mine perhaps 10 years ago.
   / deere 1050/ yanmar 336d same exact tractor? common issues? #14
Hoye has Heavy duty axles that they custom Make for some of these models.
   / deere 1050/ yanmar 336d same exact tractor? common issues? #15
Our axles are really only for the smaller 2wd models (YM1500, 1700, 2000). I don't think you would see any advantage on the bigger models like the 336.
Yanmar did 3 upgrades to that 4wd spindle over the years. If I remember right the last upgrade was sold as a heavy duty kit that included a new spindle, gear, and cover plate.
   / deere 1050/ yanmar 336d same exact tractor? common issues? #16
My parts manual for a JD 850/950/1050 shows the frames and axles and stuff to be swapable. Just that the engine for the 850 is a 3T80 and the 950/1050 is the 3T90 engine. The 1050 gets the turbo.
The JD1050 in the Yanmar is the rare YM4300. There are several here in the USA and Canada, but much more popular in Australia.
If you know how to poke around the John Deere service parts site, you can find all of the explode view part drawings with part numbers.
Hoyes parts for a YM4300 aka JD1050 ...
YM43_43D: Yanmar Tractor Parts
Here's a rare YM4300 that was refurbished.
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
2008 Chevrolet C7500 Altec TA40 41ft. Bucket Truck (A59230)
2008 Chevrolet...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
2019 CATERPILLAR 336 EXCAVATOR (A60429)
2019 CATERPILLAR...
CASE IH 120A FARMALL TRACTOR (A60430)
CASE IH 120A...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A61306)
2023 Takeuchi TL6R...
