deck removal
/ deck removal #1
jam2004
central NJ
Kubota BX 2230
I'm trying to get the 2230 ready for winter by removing 54" deck. The L links are giving me one heck of a fight. Am I doing something wrong? The deck is set to zero. I'm pulling hard on them, but the springs aren't budging. I only do this per year, so it takes me awhile to relearn everything.
/ deck removal #2
are your wheels set right. adjust them all the way down. try setting a 2x4 on each side under the wheels if the above does not work.
/ deck removal #3
Yea,
You need to make sure all the pressure is off the deck for the pins to give out easily. You might want to put blocks under the wheels and double check that you are set at zero.
/ deck removal
Finally got it. I had to WD40 the the L clips and spin 'em a bit to get them to come out. Thanks.
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
ELECTRIC POWER WASHER (A64278)
ELECTRIC POWER...
2026 SDLANCH SDLC2020 High-End Carport (A64194)
2026 SDLANCH...
2022 EZ-GO ELITE...
Small Gun safe (A64557)
Small Gun safe...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
