deck removal
/ deck removal #1
jam2004
central NJ
Kubota BX 2230
I'm trying to get the 2230 ready for winter by removing 54" deck. The L links are giving me one heck of a fight. Am I doing something wrong? The deck is set to zero. I'm pulling hard on them, but the springs aren't budging. I only do this per year, so it takes me awhile to relearn everything.
/ deck removal #2
are your wheels set right. adjust them all the way down. try setting a 2x4 on each side under the wheels if the above does not work.
/ deck removal #3
Yea,
You need to make sure all the pressure is off the deck for the pins to give out easily. You might want to put blocks under the wheels and double check that you are set at zero.
/ deck removal
Finally got it. I had to WD40 the the L clips and spin 'em a bit to get them to come out. Thanks.
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
2006 Volvo VNM T/A Day Cab Truck Tractor (A64556)
2006 Volvo VNM T/A...
3269 (A63117)
3269 (A63117)
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A64553)
2025 BrushFox...
213088 (A64276)
213088 (A64276)
2026 SDLANCH SDLC2020 High-End Carport (A64194)
2026 SDLANCH...
