Bob_Young
- Joined
- Jul 5, 2002
- Messages
- 1,244
- Location
- North of the Fingerlakes - NY
- Tractor
- Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
Bigger rear tires make for a smoother ride on rough ground. If your 12 acres is something other than lawn and if you don't like being jostled around while you're working; you might find the L-series Kubotas or the TC30 easier to live with than the smaller tractors.
I can attest that rough ground will slow me down significantly on the B7610; though I suppose running the tires a bit soft would soak up some of the bumps.
3 cylinder vs. 4? Not worth wasting time on. Both are good and the 3 cylinder gives up nothing in smoothness.
Bob
Bob
