Decent tow behind broadcast spreaders
   / Decent tow behind broadcast spreaders #1
zuiko
Platinum Member
Minnesota
JD 990 4WD
Is there such a thing? I have the "125 lb" agrifab spreader with pneumatic tires that you see pretty much everywhere for about $150 (its the push version, not the tow version, but I think they are identical other than the pushing/pulling hardware) and I am not happy with it.
The plastic gearbox is really weak. The two axle shafts end in the plastic gearbox which has sagged/worn to the point where the axle is no longer straight and wobbles. As a result the whole unit doesn't work very well any more. Maybe it is the result of overloading but I never put anywhere near 125 lbs in it. Maybe 80# at the most.
Is anybody out there making a spreader with a strong (preferably metal) gearbox? Or any ideas to fix the agri-fab? Not sure what I could do besides replace the gearbox... and it doesn't look like it is really made for anything on it to be replaced.
   / Decent tow behind broadcast spreaders #2
There are some very good quality spreaders made, but you won't find them in a box store or at Northern Tool and such places. Places that sell professional lawn care equipment would have them, but I think many are more expensive than the average land owner can justify. Every once in a while I see one for sale on Craigslist or Ebay.
   / Decent tow behind broadcast spreaders #4
I use a Brinly Hardy 175lb broadcaster spreader and have found it very reliable.
   / Decent tow behind broadcast spreaders #5
How old is your Agri-Fab spreader?
I have their 175# version, bought it in '99. It has all metal gears and grease fittings on the axle. It has held up well. Only problem I've had with it is the on/off handle is too far to reach from the seat of my NH now. I use a telescoping pole with a hook on the end (at the place I bought it they called it a body pole - as in, used to pull dead bodies out of the water:(:ashamed:). I use it to push/pull the handle as needed.
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
2015 KENWORTH T680 SLEEPER TRUCK (A54313)
2015 KENWORTH T680...
Frontier WR1008 - 8 Wheel Pull Type Hay Rake (A55218)
Frontier WR1008 -...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
