Decent tow behind broadcast spreaders
   / Decent tow behind broadcast spreaders #1
zuiko
Platinum Member
Minnesota
JD 990 4WD
Is there such a thing? I have the "125 lb" agrifab spreader with pneumatic tires that you see pretty much everywhere for about $150 (its the push version, not the tow version, but I think they are identical other than the pushing/pulling hardware) and I am not happy with it.
The plastic gearbox is really weak. The two axle shafts end in the plastic gearbox which has sagged/worn to the point where the axle is no longer straight and wobbles. As a result the whole unit doesn't work very well any more. Maybe it is the result of overloading but I never put anywhere near 125 lbs in it. Maybe 80# at the most.
Is anybody out there making a spreader with a strong (preferably metal) gearbox? Or any ideas to fix the agri-fab? Not sure what I could do besides replace the gearbox... and it doesn't look like it is really made for anything on it to be replaced.
   / Decent tow behind broadcast spreaders #2
There are some very good quality spreaders made, but you won't find them in a box store or at Northern Tool and such places. Places that sell professional lawn care equipment would have them, but I think many are more expensive than the average land owner can justify. Every once in a while I see one for sale on Craigslist or Ebay.
   / Decent tow behind broadcast spreaders #4
I use a Brinly Hardy 175lb broadcaster spreader and have found it very reliable.
   / Decent tow behind broadcast spreaders #5
How old is your Agri-Fab spreader?
I have their 175# version, bought it in '99. It has all metal gears and grease fittings on the axle. It has held up well. Only problem I've had with it is the on/off handle is too far to reach from the seat of my NH now. I use a telescoping pole with a hook on the end (at the place I bought it they called it a body pole - as in, used to pull dead bodies out of the water:(:ashamed:). I use it to push/pull the handle as needed.
2007 Fontaine DFT-5-8048WSAWK 48ft 35 Ton Drop Deck Equipment Trailer (A52377)
2007 Fontaine...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2019 Kia Soul SUV (A53424)
2019 Kia Soul SUV...
