Decent tow behind broadcast spreaders
   / Decent tow behind broadcast spreaders #1
zuiko
Platinum Member
Minnesota
JD 990 4WD
Is there such a thing? I have the "125 lb" agrifab spreader with pneumatic tires that you see pretty much everywhere for about $150 (its the push version, not the tow version, but I think they are identical other than the pushing/pulling hardware) and I am not happy with it.
The plastic gearbox is really weak. The two axle shafts end in the plastic gearbox which has sagged/worn to the point where the axle is no longer straight and wobbles. As a result the whole unit doesn't work very well any more. Maybe it is the result of overloading but I never put anywhere near 125 lbs in it. Maybe 80# at the most.
Is anybody out there making a spreader with a strong (preferably metal) gearbox? Or any ideas to fix the agri-fab? Not sure what I could do besides replace the gearbox... and it doesn't look like it is really made for anything on it to be replaced.
   / Decent tow behind broadcast spreaders #2
There are some very good quality spreaders made, but you won't find them in a box store or at Northern Tool and such places. Places that sell professional lawn care equipment would have them, but I think many are more expensive than the average land owner can justify. Every once in a while I see one for sale on Craigslist or Ebay.
   / Decent tow behind broadcast spreaders #4
I use a Brinly Hardy 175lb broadcaster spreader and have found it very reliable.
   / Decent tow behind broadcast spreaders #5
How old is your Agri-Fab spreader?
I have their 175# version, bought it in '99. It has all metal gears and grease fittings on the axle. It has held up well. Only problem I've had with it is the on/off handle is too far to reach from the seat of my NH now. I use a telescoping pole with a hook on the end (at the place I bought it they called it a body pole - as in, used to pull dead bodies out of the water:(:ashamed:). I use it to push/pull the handle as needed.
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2014 International DuraStar 4300 Street Sweeper Truck (A52377)
2014 International...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
1984 Ford LTD Crown Victoria (A52377)
1984 Ford LTD...
PALLET OF SCAFFOLDING (APPROX. 7 PC) (A52706)
PALLET OF...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
