decent cylinder for log splitter
/ decent cylinder for log splitter #1
skylarkguy
Platinum Member
Dallas Oregon
Mitsubishi MT372, Ford NAA
I'm on the long approach for a log splitter build. My BIL gave me one of these (used) PRINCE Cylinder,hyd,2 1'/'2 Bore x 16 In Stroke - Hydraulic Cylinder - 5Z366'|'PMC-5416 - Grainger Industrial Supply
The only problem i see with it is that it's previous life was on the bottom of a tilting trailer and it has a bevel ground into the body of the cylinder and the end of the rod from dragging on the ground. But it isn't leaking. My plan is to make a splitter that splits wood on both strokes. Is this gonna do it?
Thanks
/ decent cylinder for log splitter #2
This cylinder would be considered too small for most splitters. Tonnage would be between 5-7 tons depending on pump output.
/ decent cylinder for log splitter #3
IMO the rod is way to small as well,
/ decent cylinder for log splitter #4
I split with a 3x16 with a 1.25 rod all winter last year. Worked great for me, I mostly split oak. It split no problem. I didn't have any thing it wouldn't split, but I don't split anything longer than 18" and no wider than 24" usually. That's just my expierence though. I say go for it if your not splitting monsters.
/ decent cylinder for log splitter #5
4" bore will give you around 15.7 tons at 2,500 psi on the push stroke. The tonnage on the return would depend on the size of the ram. This is the size cylinder you will find on most of the "22" ton splitters being sold.
/ decent cylinder for log splitter #6
I would not go smaller than the 4'' bore. I missed out on buying a two way splitter that a man had made who worked on Hyster forklifts for a living. He knew what he was doing because he did this for a living. Ran the thing off a forklift also. They sold his pile of split firewood for over 900 dollars. He built it and used it.
Thanks for the replies. I kinda thought it might be on the small side. Might work for a log lift though...this is all in the future as I accumulate parts.
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59905)
2019 INTERNATIONAL...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
(1) 48"X7 1/2' ADS DRAINAGE PIPE (A60432)
(1) 48"X7 1/2' ADS...
(20) WOOD PALLETS (A60432)
(20) WOOD PALLETS...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
