Debris screen
/ Debris screen #1
MESSMAKER
Bluegrass,KY
DK4710SE
How do you remove the screen in front of the radiator? It looks as if it should slide out for cleaning but on further inspection it appears as if you may have to remove the section above it to give it room to be pulled out through the top.
/ Debris screen #2
It should be made for easy removal.
My Massey has a small tab at the top that I pull up to remove the debris.
It makes no sense to have one bolted on...you need to remove it very often if you are bush hogging or in any dirty/dusty environments.
While cutting, I can watch the temp gauge rise within an hour or two telling me to stop and clean out the screen.
Ivan.
/ Debris screen #3
What tractor? On my CT230; lift hood, remove the lower panel on right side, take screw out of debris screen on right side, lift the loader, and slide it out from the side.
/ Debris screen
I did not see the quick release tabs on the right side panel.I would not have thought you would have to remove a body panel. I got it now. Thanks
Caterpillar 416-442D Backhoe Service and Parts Manuals (A63117)
Caterpillar...
(2) DROP LEGS (A64280)
iDrive TDS-2010H...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2014 Kia Sorento SUV (A61574)
2014 Kia Sorento...
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
