dearborn disc parts?
/ dearborn disc parts? #1
887
canada
montana r3644
hi I recently bought a 6 foot Dearborn lift e disc for $250. the guy said it has 14 inch blades, is he correct ad where could I buy new replacement ones? please tell me more about the disc ad operating it. it is my first disc ad I am only 13 years old growing some vegetables.
/ dearborn disc parts? #2
Sounds like a decent buy, but the blades were most likely 16, 18 or 20" blades, originally. If you want to know, measure from the axle to the closest part on the frame. Leave about 1" off of the measurement for clearance and double the number to find the maximum blade diameter that the disc originally had.
Nevertheless, if it still tills decently, then use it as it is. Blades can be purchased from many tractor dealers and aftermarket are usually the best way to go, but especially with an older disc like yours.
For parts, go to any New Holland dealer or go online to Messicks Equipment, look under parts, put in Dearborn Disc and select which model you have. Some parts are obsolete, but can be had aftermarket.
What parts do you need and is yours a tandem or offset?
Have fun and keep farming! America needs you.
thank you. yeah I think they were 16 inch blades. I don't really need any parts for it but just wanted to know I case I do. it is a tandem disc
TITAN 84RAKEV2 - 84" HYD LOG GRAPPLE (A64277)
TITAN 84RAKEV2 -...
Danuser 3Pt Post Driver (A66408)
Danuser 3Pt Post...
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
2007 Isuzu NPR-HD Crew Cab Knapheide Service Truck (A64556)
2007 Isuzu NPR-HD...
2000 Pro Stock Utility Trailer (A66285)
2000 Pro Stock...
Engine knock
Engine knock
