Dearborn 10-2 plow
/ Dearborn 10-2 plow #1
VOL54
NW Tennessee
New Holland TC45DA, John Deere 345
I am thinking of buying a Dearborn 10-2 plow that needs the shares replaced (very poor welding job). I'm having trouble finding a source for Dearborn shares. It seems that I remember reading somewhere that Dearborn and Ford parts were interchangeable. Can anyone confirm or deny this interchangeability and also refer me to a source for the parts I need? Also....the seller tells me that a 10-2 is a 14" plow, but all the sources I've found say it's a 12". Comments??? Thanks.
/ Dearborn 10-2 plow #2
VOL54,
Measure from the furrow side of the landside to the "Wing of Share" point straight across this will be 12", 14" 16". This is your width. See attached doc.
Hope this helps.
Idaho2
/ Dearborn 10-2 plow #3
VOL54,
I found that Wiese has a plowshare cross reference for a lot of plows. If you have an OEM number or bolt pattern it will cross reference to a Weise number.
idaho2
/ Dearborn 10-2 plow #4
Ford shares will work.
Ronnie
/ Dearborn 10-2 plow #5
Dearborn was Ford's implement division and now parts references can be found on New Holland's website or through dealer's website. Attached picture is from website. New Holland doesn't supply anymore, but as stated previously, measure hole spacings and compare. Weise is a maker of parts, but generally sells to dealers in multiple quantities. I have some shares, but would have to look and see if they cross to original number, 107458. Also, many other sources if you Google, but not necessarily correct.
