Dealing with Mud
/ Dealing with Mud #31
Barryh said:
This one looks to be made for ATV, Yard Tractors. I'm going to go ahead and get it. Guessing it also has low amp draw. I don't think it would hurt your battery that much. It's also remote radio controlled. ;)
My guess is even at 4,000 lbs, with the tractor spinning wheels, and with the winch pulling. It should work it's self out of trouble. The big question is, do you have many trees near by for hook up. ;)
Harbor Freight Tools - Quality Tools at the Lowest Prices
I have a 2000 pound winch for my 422. It is marginal for this machine. Be sure to get a snatch block pully to double your pulling power. That should give you enough. I seem to do most of the pulling from the back. Usually if I am stuck, I don't want to go further into the swamp and use the winch to back out. One of the nice things about electric versus manual is you can pull with the winch from the driver's seat and combine the two forces.
/ Dealing with Mud #32
Tim_in_CT said:
I bought a cheap $60 gorilla 1500# winch off of ebay.
I'll stick up for the cheap Gorilla winches, I got a 2500lb one for my ATV and it's been quite reliable (used, but only lightly thus far). They might even be cheaper direct from Gorillas web site than from ebay.
/ Dealing with Mud #33
I was actually very impressed with the gorilla winches. The winch came with absolutely EVERYTHING you need; enough wire to completely hook it up (with shrink wrapped terminals), a contactor with built in circuit breaker and a sealed toggle switch to mount on your dashboard. I bought the optional key chain remote, which is pretty nifty. Much higher quality package then I expected for the price.
/ Dealing with Mud #34
I have the 4000 lb (I believe) gorilla waterproof winch with the wireless remote. Broke the first time I used it - the side of the aluminum spool broke off. They sent me the wrong part. When I let them know that, they sent me a new winch. GorillaWinches.com - I paid a little more than some sites but it came with a much better warranty. They were a real standup company to deal with. I highly recommend them.
It is not an industrial winch but a nice winch for the price. i switched to the synthetic rope they had.
Used the winch to lower a lathe out of the second story of my barn (had built the barn with a cantilevered beam for this purpose - finally used it after 16 years!). Had it all hooked up and my brother recommended that I drive the truck further back for a better angle. Did so and then went upstairs with the wireless remote. Raised the lathe up and swung it out the barn. Then started lowering it. Got about halfway down and it started coming back up. Reversed it and it when back down and then started coming back up. :confused: Thought the remote was screwing up (first time using it). All of sudden - crash and the lathe is on the ground. Thought I broke the beam but it was fine. Figured I must have broke the rope but that made no sense. :confused::confused: Went down and saw the rope had come off the winch :eek: I was an idiot! The rope was not long enough to lower the lathe after the truck was moved (I had checked before moving the truck) so it came off the spool. The going up and down was the rope wrapping around the other direction. I am sure most of you realized that from the symptoms. We could not see the winch so we did not know that was what was happening. I do not think I will make that mistake again. Fortunately, everything was okay - just broke a few bolts.
There really is no limit to my stupidity at times!
Ken
/ Dealing with Mud #35
Ken
Ken, you have a great deal of company in this. You made me think of the time when we were in a hurry to go skiing with friends. So I quickly put the brand new ski racks on the car roof, inside the garage. Open the garage door, then start to drive outside. Except for that sickening crunch I heard. I'd not checked that I had enough clearance for the ski racks under the lip of the door. I busted up part of the ski rack, plus bent the drip rails on the car.
John
/ Dealing with Mud #36
woodlandfarms said:
So, my PT is 4,000lbs. Can a 3,000lb winch work?
You are trying to pull your PT out, not lift it up!! So any amount of pull may be enough to help!
I once had a 24' drywall delivery truck stuck in the snow of my driveway after it unloaded the drywall. All I had was a 2WD station wagon with studded tires, but I pulled that truck nearly 100' out to the road, FIVE FEET AT A TIME!
I used a 15' NYLON towstrap. Several times with the towstrap attached to my hitch and the front of the truck, I would back up bumper to bumper, then drive off as fast as I could. At 15' the towstrap would begin to stretch, the wagon would smoothly come to a stop, and the truck would advance 5' closer to the road! In less than a half hour the truck was out going down the road!
I have found that 'log chains' and steel cables usually don't work, but are more likely to damage the vehicles.
/ Dealing with Mud #37
Yep. A snatch strap will allow a much smaller vehicle to pull a much larger vehicle out of some pretty sticky situations if the smaller vehicle has some traction. Heck, my kid had to use the PT425 to pull my van out of the driveway a couple weeks ago. The weight difference is almost 4500 pounds. The van had sunk in soft bottomed gravel with a snow covering on a warm day. Then it froze up real fast. The van just could not climb that small incline out of the tire depressions. Probably only an inch or so. So we put the snatch strap between the two, she took off down the driveway and just kept pressure on the van until I could drive it out.
Deere 335P (A53317)
Deere 335P (A53317)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
