Dealer meeting
   / Dealer meeting #2
Nice! ...after watching that CK2610 cab / mower options, I might actually consider changing colors!
   / Dealer meeting #3
   / Dealer meeting #4
I was reading your posts on the problems with that. I take it they have not fixed it yet? Have you had any information from Kioti or the dealer yet. I'm looking at the CK3510se and was just curious.
   / Dealer meeting #5
You are aware of Kioti having their computers hacked and shut down for weeks. Then the parts dept. was all messed up. I spoke with the dealer today about my tractor. He told me that they replaced the bad injector that I had. They ran tests on it and it showed that it is fine. For some reason they ran more tests and they came back bad. They have sent those codes off to Kioti because it is under warranty and they, Kioti, has to decide what to authorize. The dealer has been fine as far as I am concerned. My tractor has a weird problem that started up around 420 hours. I think the ECU is bad along with the #2 injector which was just changed out. The dealer thought that just maybe the mixed codes from that injector were laptop computer related. They bought a new computer and still have the same error codes showing up. I loved using this machine when it was running. Mowing my fields is a breeze with the cruise control set. I have yet to find a normal task that I cannot do with this tractor. I just wish it was here and running right. I burn wood and didn't bring any over to the house prior to the cold snap. My logging road is blocked off and requires a tractor to open it up. Now I am using oil to heat my house and not very happy about it. I did mention to the dealer that I was going to call Kioti on Monday and shake them up a bit. I said 3 months and still not fixed for the same problem for the 3rd time is no longer acceptable. I was told that Kioti has the say on what to do and what to try on warranty issues.
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
HYD PUMP & TANK SET (A51248)
HYD PUMP & TANK...
2014 Ford Escape (A51694)
2014 Ford Escape...
2025 INDUSTRIAS AMERICA FT510 5'X 10' HYD DUMP TRL (A51247)
2025 INDUSTRIAS...
2012 TRAVIS 39FT DUMP TRAILER (A53426)
2012 TRAVIS 39FT...
PORTABLE UP RIGHT FUEL TANK (A51248)
PORTABLE UP RIGHT...
