Dealer meeting
/ Dealer meeting #2
Nice! ...after watching that CK2610 cab / mower options, I might actually consider changing colors!
/ Dealer meeting #3
/ Dealer meeting #4
I was reading your posts on the problems with that. I take it they have not fixed it yet? Have you had any information from Kioti or the dealer yet. I'm looking at the CK3510se and was just curious.
/ Dealer meeting #5
You are aware of Kioti having their computers hacked and shut down for weeks. Then the parts dept. was all messed up. I spoke with the dealer today about my tractor. He told me that they replaced the bad injector that I had. They ran tests on it and it showed that it is fine. For some reason they ran more tests and they came back bad. They have sent those codes off to Kioti because it is under warranty and they, Kioti, has to decide what to authorize. The dealer has been fine as far as I am concerned. My tractor has a weird problem that started up around 420 hours. I think the ECU is bad along with the #2 injector which was just changed out. The dealer thought that just maybe the mixed codes from that injector were laptop computer related. They bought a new computer and still have the same error codes showing up. I loved using this machine when it was running. Mowing my fields is a breeze with the cruise control set. I have yet to find a normal task that I cannot do with this tractor. I just wish it was here and running right. I burn wood and didn't bring any over to the house prior to the cold snap. My logging road is blocked off and requires a tractor to open it up. Now I am using oil to heat my house and not very happy about it. I did mention to the dealer that I was going to call Kioti on Monday and shake them up a bit. I said 3 months and still not fixed for the same problem for the 3rd time is no longer acceptable. I was told that Kioti has the say on what to do and what to try on warranty issues.
LandHonor LHR-AGC4400 4400lb Adjustable All-Steel Gantry Crane (A60352)
LandHonor...
2023 GMC 1500 Sierra Elevation Crew Cab 4x4 Pickup Truck (A60352)
2023 GMC 1500...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
