Deadly Blue Green Algae
/ Deadly Blue Green Algae
For instance, my dump trailer and container are covered in MOSS. That has never happened before.
/ Deadly Blue Green Algae #27
Aside from the obvious about drowning, the points in the link you provided are foreign to me. Although I don't recommend drinking untreated water, or swimming in beaver ponds; I've never really known or thought about unsafe water. Perhaps it's because most of ours flows fast enough so that it doesn't get stagnant?
/ Deadly Blue Green Algae #28
Fresh water ain't fresh. I remember as a kid we carried Halazone tablets when camping. You didn't drink untreated or unboiled water.
/ Deadly Blue Green Algae #29
No, but my dog certainly does. :D
/ Deadly Blue Green Algae #30
"Fresh water ain't fresh." <- That's a good way of putting it ..... I'm going to need to try and remember it.
I'm right there with you on not drinking unboiled or untreated water .... though (if I'm recalling it correctly) from what I was taught even boiling & treating doesn't get rid of all the hazards -- just most/all (depending on what's present) of the living ones.
If I recall correctly one of the things we were taught in grade school was boiling and water treatments were good measures to use, but the safest treatment for surface water sources (if time and resources were available) was to distill the water by condensing water vapor on the underside of a pan/clean surface and funneling that into a canteen/reservoir for drinking. Which if memory serves was also taught with the fact that combustible containers (like paper cups, and birch bark pots) won't burn as long as they're in contact with water since the water takes the heat to boil and in doing so keeps the combustible material below its ignition point. The only (slight) disadvantage to distilled water is that it doesn't have some of the essential trace minerals that other water sources can provide. The other disadvantage was that distilling requires a fair amount of time and material (a container to boil water, a sanitary surface to collect and condense the water, a suitable container for collection, and all the fuel to boil the water).
Again going from memory: stagnant water was the most likely to support things growing in it, but even running water wasn't completely free of hazards as where it was running from, and what it might be eroding and carrying along could introduce it's own set of hazards. For example: mineral concentrations (even the safe ones can reach hazardous concentrations), runoff from areas with lots of fecal, or decaying matter present, along with all the obvious (and some not so obvious) human-caused hazards. (I'd rather not take this discussion into all the things that may not get tested for, monitored, or filtered out of public water sources, which may also find their way into surface water sources).
The other "good" sources of water were melted snow, and intentionally collected rainwater (assuming there isn't a whole lot of air pollutants in the area -- though frequent/hard precipitation can help reduce that, by knocking it down and putting the previously airborne material into surface water sources).
A few more useful links I just found:
WATER SAFETY FOR CAMPERS
A Guide to Drinking Water Treatment and Sanitation for Backcountry and Travel Use | Camping, Hiking, Travel | Drinking Water | Healthy Water | CDC
Ground Water — Safe Drinking Water Foundation (this one looks to have links to a fair amount of other educational material ... I think I may even have experienced some of the older versions of the EPA educational activities when I was in grade school a few decades ago)
Over all it's not something to be paranoid about, but it is something to be aware of so if/when the need arises you can make the water safe (enough) to drink. ...and of course this is one of those things where not knowing can indeed result in sickness or even death.
/ Deadly Blue Green Algae #31
40 years ago it wasn't at all uncommon to be driving down the road and see a spring where people stopped to get water. Often these had been used since time immemorial, and some were once used to bottle water. (My father had one of these on one of his properties.) Now most of them have been capped, and if there is one available the landowner is responsible to have it tested every year. I had one dug out on my property and when we hit ledge the water was boiling out in three places. During a drought I pumped 10,000 gallons of water out of it before it went dry. Yet it failed the water test, and I never tried to fix it.
One thing that I have and should be carrying is a water filter; I can put a quart of unclean water in and it will (supposedly) come out the other end clean.
/ Deadly Blue Green Algae #32
I'm reminded of a situation many years back. There was an extended power outage. I was talking to a neighbor who was concerned about where he would get water since his well pump wouldn't work without power. I looked around the several acres of yards with 6-8" of new fresh snow and the 500 gallon propane tank feeding his gas stove and furnace ....
/ Deadly Blue Green Algae #33
20 years ago, this house didn't have water. Previous owner tried to get a well drilled and came up dry (pun intended). Owners before them had a 1,000 gallon cistern that would be filled by a local water truck. When I first moved in, that all I had. Every few weeks, I'd had to call the guy and have water delivered. He'd go to a certain place along the road, drop a hose in a running spring, start his gasoline pump and fill up. I'd pour a cup or so of bleach in the cistern as he dumped the load. Never got sick or had any problems.
Luckily that only lasted about 5 years before the county system installed water lines to most every one.
/ Deadly Blue Green Algae #34
You're really knocking out the play on words today! :D
/ Deadly Blue Green Algae #36
Also, it's not really algae, it's a bacteria.
Cyanobacteria - Wikipedia
So, I have a couple of areas (That I made) on my property to tank some water (all surface) for the critters. This year weather wise we have been very hot and dry and I can tell that the critters are not visiting it as much (game cams) and I am seeing it quite green. Well, I want to see if I can clean this up so today I added 2 of these tablets. So, will see if it gets better in the next few weeks. The stuff is not cheap but if it works I guess I will keep it going at least in the hot months.
/ Deadly Blue Green Algae #37
Interestingly enough that article includes links to the same site I posted earlier -- so as I've said in prior posts this seems like a lack of education issue that's resulting in people being surprised. . . .
I think there is a lack of basic education in sanitation everywhere! When I was growing up, washing your hands after the bathroom and before you ate was a given. Now, businesses have to post signs, etc reminding their employees . . .
/ Deadly Blue Green Algae #38
I notice moss growing on all kinds of seldom moved stuff around here and I have never experienced that before.
never experience what?
Moss. Even on roads.
I've seen it in places that don't get as much Sun as others.
Nice play on words. :thumbsup:
Yes it was :laughing:
Y'all thought I was funnin' ya', didn't ya'?
Just a few small patches left. Used to be a lot more, even out into the cracks in the pavement, but the recent dry weather has killed a lot of it off.
2013 MACK CHU613 WINCH TRUCK (A67714)
2013 MACK CHU613...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
Asphalt Melter (A61572)
Asphalt Melter...
Craftsman 16in Variable Speed Scroll Saw (A64553)
Craftsman 16in...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2009 CATERPILLAR CP56 PADFOOT ROLLER (A65056)
2009 CATERPILLAR...
