Dead Iseki.
/ Dead Iseki. #1
yomax4
Elite Member
Midwest
ISEKI TA 247. Stihl Saws Gravely Zt's Polaris ATV's State Of The Art Welding Equipment
Today I pulled a few small stumps. My TA247 ran great like always. When I went to move it to the shed I turned the key and nothing..Any other time I would turn the key to On and wait for a dozen clicks. Elect Fuel Pump? Or Glow Plugs. Unsure.. But this time Nothing. I put a 12v meter on the battery and it was 95%. I jumped a screwdriver accross the Solenoid and it would ckick. Nothing more. Can I expect that my starter suddenly went out? Or is there some safety thing Im unaware of. This is a Beautiful Tractor. Want to buy it? Any help would be great!.. Thanks.
/ Dead Iseki. #2
Sounds like a battery cable to me. Take them of an clean the ends then put them back on.
/ Dead Iseki.
Thanks for the reply.. I did just clean up the battery cables. Also I have 12v at the starter. :confused:
/ Dead Iseki. #4
Are there any safety switches that could be the issue, maybe on the clutch or seat?
/ Dead Iseki. #5
If your cables are good, the battery is good, & you jumped a screwdriver across the Solenoid and it would click & nothing more, you have a bad solenoid. If you can give me the # from the starter, I should be able to supply you with a cheaper solenoid than what is available from Iseki..
/ Dead Iseki. #6
Hi when you cleaned your cables did you clean the negative cable where it bolts to the frame?
/ Dead Iseki.
Thanks everyone. I did clean the Negative cable at the frame. That was it but the cable was a bit loose on the solenoid too. I knew this unit would never let me down. It was my self inflicted stupidity to not recover all the bases. Problem Solved> thanks again.
/ Dead Iseki. #8
Welcome to TBN, glad you figured it out. You must of scared it into submission with the "Want to buy it?" comment.;)
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
2022 EZ-GO ELITE...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
