DDT & Lyme disease
   / DDT & Lyme disease #91
Like this Steve?!:) To tell the truth, I was not aware of the particulars you outlined above, or I would likely have been using them prior to now.....so thanks for the 'skoolin' :)
Example comment.
I'm away on vaca, so have not responded to this thread for a few days. Here are your two sentences Steve, so show me the way to enlightenment by all means!:)
Here's my reply. I will post a screenshot of what I did.
Steve
   / DDT & Lyme disease #92
Here's the screenshot.
1. I added /QUOTE in brackets at the end of your first sentence.
2. I added my comment.
3. I copied and pasted (QUOTE=Coyote machine;4850225) from the first line to the beginning of the second quote. NB -- I have to use parentheses here rather than brackets to avoid creating a superfluous QUOTE.
Also, if you click on the blue "thingy" following a poster's ID, you will be directed to the post in which the material in the quote originated.
Steve
   / DDT & Lyme disease #93
Steve
So, clicking 'reply with quote' brings up the, for example:
text, and then one can close a quote at any point in its ensuing text, and then go on and repeat the process as desired....
I was having difficulty seeing where one 'acquired' the post # data; now I see it is automagic with 'reply with quote'.
Guess it was just not registering that the info was there when I quoted a post/partial post; since it was right in front of my face, :duh::)
BTW Steve, the blue thingy is called a 'link back', which you should know because Arron referred to it in post #74. Pay closer attention now, Steve!:):)
2007 GMC 2500HD (A56436)
2007 GMC 2500HD...
7ft Metal Shell Pump (A57454)
7ft Metal Shell...
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
CAT Chassis Only (A59076)
CAT Chassis Only...
2018 Peterbilt 389 Day Cab Truck, VIN # 1XPXD49X6JD476305 (A57453)
2018 Peterbilt 389...
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
