Davis D100A backhoe
/ Davis D100A backhoe #1
mmurphy
Platinum Member
I am trying to find some parts for the D100A backhoe.
Hoping someone may have some leads of anyone carrying parts for it. Thanks.
/ Davis D100A backhoe #2
Other than the dipper and boom and frame and bucket, most everything else (valves, pins, cylinders, etc.) are likely common. What do you need?
/ Davis D100A backhoe #3
What parts are you needing, I have the case version D100 and most parts are the same so you may check with the case ih dealer.
Case bought them out years ago.
Bottom bearing and possibly the pivot pin that rotates with the bottom boom. Top piece broke off, thought it maybe pressed in through a tube, but after getting bearing off, found it to appear it was one machined piece of metal. I am concerned about having it welded for you would have problem getting straight enough.
Thanks, will try Case IH dealer.
1979 Ford 5000 (A64126)
1979 Ford 5000...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2009 Kershaw 75-G2 Sky Trim (A65579)
2009 Kershaw 75-G2...
2000 Malibu (A62613)
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
