Dash camera advice needed
/ Dash camera advice needed #1
deerefan
Veteran Member
louisiana
1952 8N, 2005 JD 5103
I drive 170 miles a day round trip, with my morning commute starting at 5am. I see a lot of crazy driving. Want a dash camera to protect myself in case of an accident, etc. What brand do you recommend?
/ Dash camera advice needed #2
I'll tell you what NOT to get -
Stay away from "The Original Dash Cam 4SK909X Twister X, Dual Lens," sold by newegg - they sent me one with an old menu that didn't let me loop on recording. Returned it.
/ Dash camera advice needed #3
I bought 2 dash cams the KD links X1. Simple setup good price on amazon $169 per unit.Folks have lost there minds on the roads.
/ Dash camera advice needed #4
My dash cam is a Vicovation bought in 2014. Works well and glad I have it. I'm sure technology has improved since and there used to be many review sites that were good back then.
/ Dash camera advice needed #5
I have the kid links as well. I chose it because it functions well below freezing so I don't have to bring it in every night or while I'm at work in winter.
I'm happy with it.
/ Dash camera advice needed #6
I've switched to hard wired cams. Used the little 808 keychain cameras for a while but the batteries kept swelling up inside them with the heat of being left in the windshield. For the most part I recommend getting a hard wired unit that starts and stops automatically and doesn't have a battery. The best ones record at 1080P in .MOV format. Most all of them record to a micro SD card so you can retrieve the data. They all loop record over old data so best to get a 32 gig class 10 card. That'll hold a couple of days worth or more.
I have two different brands in the same case but they work different. One records AVI files that won't play back in Windows Media Player but I can play them back on my Android head unit in my truck. One thing I like about that one is it records GPS location and speed so if I needed to use the info to prove innocence it would have all the data.
The other is a Road Rover I bought for about $55 off Amazon. It doesn't record location or speed. That unit has gone up in price so I just ordered a couple of new ones with a similar description off ebay. Those cost $17.54 for one and $38.75 for the other. They have identical specs as the Road Rover but one uses a different type case I think might work in the rear window as well as the front. Haven't tried either yet since the first one just arrived today. One or both of these will go in my wife's car.
Here is some footage from the Road Rover.
/ Dash camera advice needed #7
I bought one off Amazon, a Toguard, never heard of it but it got great reviews and they were right. Tiny thing so I was a bit leary when I got it but the video is great, hi def and has sound.
One to stay away from is a Garmin which is the first one I bought. Dumb me didn't bother checking reviews and there are numerous instances where it would keep rebooting which mine started doing. To add insult to injury, you have to use their power supply, if you don't it won't work. I found that out because I wanted to hard wire it into my truck so I bought a 5V power supply, hooked it up to a switched power source in the fuse panel and....nothing.
One thing to watch is the mount. Mine only came with a suction mount which would work great except the inside of the top of my windshield is textured and the suction wouldn't work. I had to make up a thin piece of aluminum and glue that to the inside of the windshield with double sided tape and mount the suction cup on that......Mike
/ Dash camera advice needed #8
Anyone using the Apeman products? They appear to have few problems and good support from the reviews on the Interwebs.
/ Dash camera advice needed #9
My truck was recently stolen and hasn't been recovered. I was mad enough to purchase an Owl Dash Camera for my Suburban. I'm super happy with it so far. It has interior and exterior camera so I can record what I see outside of my windshield but also the interior of my car. I got for the interior feature because I wanted video of anyone breaking into my car.
The camera hard wires to your ODB port and has a cellular connection that uploads video to an app on your cell phone. Installation was incredibly easy and looks very neat. I was able to install it in 3 minutes and you can see a wire. They give you everything you need to do this.
The only negative that I think anyone could give is the price but I didn't mind spending any amount of money for a high quality clean looking camera. Google Owl Camera and you will find it. I'm not allowed to post links in this forum as I am a newbie.
Spence Dilworth
Baton Rouge, LA
Spence Dilworth
Baton Rouge, LA
Thanks Spence. I work in BR and drive I-12 daily from Covington. I think you can confirm how crazy driving is here.
/ Dash camera advice needed #11
My Garmin combo GPS and dash cam works well for me.
/ Dash camera advice needed #12
I bought a Rexing F10 from Amazon earlier this year, it's been a good camera so far. No GPS support though. Can't include a link since I don't have enough posts yet.
Thanks guys for all the input. I will purchase one in the next week or so and let you know which one I chose and why. Thanks again!
/ Dash camera advice needed #14
I have 3, ok quality, decent support.
/ Dash camera advice needed #15
/ Dash camera advice needed #16
i have a KD links one as well. only one i've had. it is pretty good
/ Dash camera advice needed #17
I have a Blackvue DR490L-2CH. I hardwired it so hid wires in pillar and headliner and auto start with truck.
High resolution is good so you can get details (license plates, etc) if needed.
Motion sensor. Mine records short video (30 sec?) if something bumps truck.
Dual front and rear cameras - don't know which way strange is coming from.
Large memory card so it does not overwrite too quickly. I also keep a second memory card in truck if I want to pull the card to save a video. Many of the newer camera are doing cellular and wifi connections to pull the videos.
/ Dash camera advice needed #18
Just got the last pieces I ordered last week. I haven't installed them yet but I powered both up and the video looks to be as good as the Road Rover example I posted above. Both are wifi and have to be set up with the FinalCam app. After they are setup they do not have to be connected to the app. They will just start recording when the engine starts and stop when you shut it off. Both have the motion detection setting so they record a short clip if the vehicle is bumped whether it's running or not. You can access the videos on your phone through the FinalCam app or just pull the sd card and download to your computer.
I also ordered two 32 gig class 10 SanDisk micro sd cards to use in them from seller suzyq5591-5. The total order was less than $80 for both cameras and memory cards.
Here is a photo and description for the one I will put in the windshield of my wife's car. It looks just like the Road Rover I have in my Mustang. This one has a harness to plug into the OBD port which will make hookup super simple. Seller was anglestore.
Package Included
1 x Car Digital Video Recorder Camcorder
Features
1. Model: 103
2. No battery no explosion. Circle recording automatically.
3. Built-in WiFi module, you can watch the recorded videos.
download the videos, share the videos from the DVR to your smart phone.
4. Support parking monitoring function can be realized car theft and evidence collection; built-in G-Sensor (3 Axis default open) collision detection sensor.
5. Support AV video output; could connect to your car DVD or car monitor screen playback.( If your car with a car DVD player or Monitor AV input, you could also connect this DVR to it for display.)
6. Support IOS and Android APP manipulation.
7. Just via WiFi, not waste your internet flow. You can search" FinalCAM"or in APP Store or Play Store or Scan the QR code on our packing box
8. Support WiFi/Microphone/Time mark/Seamless Recording/Video Playback/Super Night vision Recording.
Specifications
1. Visual Angle: 170 Degree
2. Recording Resolution : 1920*1080 30fps/1280*720 60fps
3. Work Temperature: -20℃~60℃ / 10℃~80℃
4. Video format: MOV/H
5. Video clip: 1/3/5 min.
6. Video codec: H.264 (MOV/H)
7. Video Output: NTSC/PAL (default NTSC)
8. Storage: TF card( 32G Max) class 6+(Not included)
9. Main Material: ABS
10.Power Supply: 12V ACC
11. Size: 8 x 5 x 4cm
Notes
A. Please don稚 take out the TF card when the DVR is working.
B. The DVR will be on/off automatically when your car ACC is on/off.
C. If there is any problem, please try to press RESET button to cover it.
D. The red part on the recorder is a sticker,please peel it off to stick on the car window
This is a photo and description for the cheaper one I plan to put in the rear window of my truck. Seller on this one was deal-runner.
Color:Car DVR installation instruction: 1.First, we have find the original car insurance box position, to be find the BAT+, ACC fuse, and GND position, If the original vehicle fuse plug the same as the DVR fuse cable plug, we can directly replace the same fuse cable harness plug, in order to the actual car fuse location accurate. 2.GND connect position: It must maintain state power, please clean up the GND connect position ground bottom gum, plastic and other such as insulation is not conductive material before installation, if there is no clean that will cause WIFI to be unable connection, without power and other issues, cause not to be work. 3.Different the original car fuse plug: if the original car fuse harness plug different driving recorder fuse cable plug, we can cut the driving recorder fuse cable plug, peel the cable skin, exposed metal wire core, wound two times around the original car fuse plug,and let fuse the roots to set aside some space inserted into the fuse box position, this picture for reference, in order to the actual car fuse location accurate. Chipset: Novatek NT96655 Sensor: Sony IMX322 Video Resolution:1080P(1920x1080)/ 720P(HD1280x720)/ VGA 640x480 File Format: Image: JPEG, Video: MOV. Power-off File Recovery Function: Support. Date Time Mark: Support. Memory Card: Support up to 32GB Class10 or upper Micro SD/TF Card. Language System: English / Simplified Chinese Dimensions:0.41ft0.22ft0.1ft Night-Vision: Supported Loop Video Clip: 1/3/5 Minutes Optional APP software: FinalCam standard voltage:DC12V
/ Dash camera advice needed #19
I have the Garmin 35 and bought it after getting a ticket because the Indiana State Trouper was sleeping on I 64. I like it and have installed a 32GB card so it last a long time before looping. Would have gotten the newer model but didn't want all of the things it was going to record. Fund out later you can turn those things off and just have it record what you want. Use a magnetic mount and it fits in front of the rear view mirror.
The cop story: Have the cruise set on 76mph and limit is 70. In the right lane and slowly coming upon a semi (BTW semi is doing 70 and is restricted to 65). Notice in the review that a mid size black chevy is coming up fast, and I mention to the wife "here comes a fast mover". The car passes and I turn on signal and ease into left lane. We are all coming around a bend and here sets a trooper in the median. I don't touch the cruise and continue on. Trooper comes out short later and as I get plenty ahead of semi, tunr signal on and go right.
Black chevy is plenty ahead of me. Cop gets behind me and says I was doing 82. So now I have a dash cam
/ Dash camera advice needed #20
I have a Viofo A119 and it's pretty good. 1440p recording and capacitor based.
I have a 64GB card and it fills up quick with the resolution. I think each 512MB is about 4-5 minutes.
2008 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2008 FORD F150...
DYNAPAC  CP271 PNEUMATIC ROLLER (A67714)
DYNAPAC CP271...
2015 Chevrolet Express Shuttle Bus (A66736)
2015 Chevrolet...
2018 Toro Workman HDX-D Diesel Utility Cart (A66734)
2018 Toro Workman...
2005 MACK CV713 MIXER TRUCK (A67714)
2005 MACK CV713...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
