Darn, I hate Harbor Freight
/ Darn, I hate Harbor Freight #1
BobReeves
Platinum Member
Tulsa OK
Ford 3000
My Bostitch brad nailer self destructed this morning so ran to HF to pick up a cheap nailer to get by with till I can get parts for the Bostitch. Well.... went in to spend $30.00 and came out an hour and a half later and spent almost $300.00. Man I hate that store.....
/ Darn, I hate Harbor Freight #2
Yeah! We can tell /forums/images/graemlins/shocked.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/wink.gif
What'dja git?
/ Darn, I hate Harbor Freight #3
Every time I go to our local HF, I'm like a kid in a candy store....
/ Darn, I hate Harbor Freight #4
I have the same problem with the Wal-Nuts superstore. I can go in for a loaf of bread and end up dropping a couple of hundred. Glad we don't have a HF store around here!
PS: what did you get?
Bought several small things to round out the shop and for a couple of projects. Air hose reel, Air filter, Air fittings, Chain, 24" cresent wrench, Welding magnets. Of course the Brad nailer and brads plus some other small stuff.
Nailer works well, might not even fix the Bostitich. The HF came with a complete rebuild kit plus a spare driver. Hard to beat for the price.
Could have easily spent a couple hundred more /forums/images/graemlins/crazy.gif
/ Darn, I hate Harbor Freight #6
I've had Harbor Freight nearby for years...
I would really like to have a Northern Tool retail store in this area, but then again, it's probably a good thing that there isn't one. /forums/images/graemlins/crazy.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/wink.gif
/ Darn, I hate Harbor Freight #7
I'm with you Andy, a Northern Tool store close by would probably delay my retirement age by about 10 years. We have a store that is locally owned called the Tool Barn, they have everything just like Harbor Freight but usually a higher quality.
/ Darn, I hate Harbor Freight #8
I have the same problem, go in for one thing and come out with 10 -
"But I needed them, hon. No really!"
/ Darn, I hate Harbor Freight #9
Tool alert !!!
Don't get the blue air dryer/filter thingy. I did, and it is junk, won't seal, one elbow was cracked, no seals on cannister bolts, etc...
One of the few things I have gotten at HF that I felt was just junk.
After working on it 6 times and using sealer, it will now hold air.
Ben
/ Darn, I hate Harbor Freight #12
Yep, that's it. The top and bottom nuts on the unit hold it togehter and sealed. However the nuts are just like acorn lug nuts with a tapered metal surface to seal against another metal surface. No gasket or anything and the surfaves are definately not precision machined.
Also the Street ell above the reg is pot metal and broke into 3 pieces when I snugged it up to try and fix a leak.
It is now a disposable use item, if the filter plugs up it gets thrown away, because the ends are JB Welded on /forums/images/graemlins/smile.gif
This is one of the few things I have not been satisfied at HF with.
Ben
/ Darn, I hate Harbor Freight #13
</font><font color="blue" class="small">( One of the few things I have gotten at HF that I felt was just junk.)</font>
Wow. I'm definitely the complete opposite. It is the rare item from HF that I don't consider complete junk. Only the few name brand items that I've bought there are still in my posession. Most items I've purchased there have not even survived a one time use! /forums/images/graemlins/mad.gif I'm more than convinced that Harbor Fright is the lower end hardware side of Big Lots.
/ Darn, I hate Harbor Freight #14
I got one of there $98 air compressors, just what I needed, works good except the cutoff switch drains the air tank when it shuts off.
So far have not been able to fix it.
Should be a one-way valve in the line from the compressor to the tank. See if it isn't stuck open or missing...
/ Darn, I hate Harbor Freight #16
Dargo,
I do not buy the stuff that is obviously junk. But have had good luck with thier welding grinders, rotozip tool, air tools, etc.
Their sliding compound miter saw has such rough slide bearings that I don't believe it would saw very straight. Found a smooth working one at Big lots though for less a /forums/images/graemlins/smile.gif $69.00. Used the heck out of it for close to 1 year now and it is still cutting good.
I would rather buy high grade tools, but at their prices would only have one or two in my whole shop.
Ben
Hi Ben,
Too late, yep that's the filter I just bought. /forums/images/graemlins/crazy.gif After reading your post I pulled it apart. It had some sort of sealant on the nuts and may not have leaked if I hadn't taken it apart, ya right. You are spot on about this being a poor design, no way is it going to seal if I put it back together.
Came up with a fix after thinking about it a bit. Made a couple of tapered copper washers using copper tubing and a flair tool. After I flared the end of the tubing I left it in the holder, used a drill press and ran a 1/2 inch step drill down the inside of the tubing. This cut the flair off the tubing and left a tapered copper washer that just fits over the stud holding the thing together. Cranked down on the nuts and no leaks, at least now I can use it and it was a pretty easy fix.
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63118)
2021 Takeuchi...
2018 Ford F-350 Crew Cab Landscape Dump Truck (A61568)
2018 Ford F-350...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
New/Unused Electric Golf Cart (A61166)
New/Unused...
UNUSED KUBOTA BT2914-24" PIN ON EXCAVATOR BKT (A62130)
UNUSED KUBOTA...
2025 Pabreak Hydraulic Vibratory Roller Skid Steer Attachment (A61567)
2025 Pabreak...
