Dangit... Accidentally caused myself a bunch of work (engine repair)
   / Dangit... Accidentally caused myself a bunch of work (engine repair) #11
Prepare yourself for more work than imagined. It probably had a hydro lock.
   / Dangit... Accidentally caused myself a bunch of work (engine repair) #12
Thought i'd make my annual appearance, what have you found?
Full rebuild... Spun bearings and damaged 2 rods with excessive heat.
New crank. 2 (of 4) new rods, new pistons, bearings & seals, bored .10 over but head and block were checked and were good. Rebuilt the fuel pump and injectors. New water pump. All new gaskets & seals. Probably more I can't remember now.
After the rebuild, she was losing coolant. Turned out the head gasket had a defect. Took the head back off and replaced with a factory CAT gasket (the first head gasket was 3rd party) and all is good.
Expensive adventure...
   / Dangit... Accidentally caused myself a bunch of work (engine repair) #14
Thanks for getting back to us...ouch$. Hope it is better than new now!
   / Dangit... Accidentally caused myself a bunch of work (engine repair) #15
Gesus this is becoming one expensive pond/hole in thr ground.
   / Dangit... Accidentally caused myself a bunch of work (engine repair) #16
Looks like you didn't have the door on there, which is probably a good thing because it may have been hard to get out in that deep of muck. I'd be interested to know the ballpark of what that repair ended up costing, if you're willing to share.
Rob
2014 JCB 930 (A57148)
LOT: (36) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #2 Grease (A59076)
LOT: (36) 14 Oz...
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
MAHINDRA 3650P TRACTOR (A58375)
MAHINDRA 3650P...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
