Danger....Huge Alert !!!! Warning !
   / Danger....Huge Alert !!!! Warning ! #13
thanks for posting the warning Brin and Artisan i had no idea this was going on my daughter is home visting so i made her and her mom read it :thumbsup:
   / Danger....Huge Alert !!!! Warning ! #14
Someone sent this around at work a couple months ago. Maybe I'm missing something, but wouldn't the contents of the bottle react and explode the bottle some short time after it was capped and tossed onto your lawn?
   / Danger....Huge Alert !!!! Warning ! #15
That's what I am thinking.
When I was juvenile delinquent we used to get granulated chlorine from my friends house(they had a pool), dump it in a pile and pour Pine-sol over it. The thing will start smoking in a few seconds, then burst into a fire so hot it makes an imprint on your retina. Of course we did this for our own entertainment...never to try and hurt anybody.
   / Danger....Huge Alert !!!! Warning ! #16
Yep, nothing new around here. Allthough around here it is called the "works" bomb. Cause " the works" bathroom cleaner is what we used.
Had the same thing using dry ice somehow at a place I worked.
Dry ice bombs are cool too. But getting the dry ice is harder than the above. Basically, its just a handfull of dry ice in a bottle, splash some water in and cap it. But chuck it quick, cause it dont take long. The water causes the dry-ice to evaporate quickly (like how they make fog in the movies). Well, the gas form of dry ice takes up WAY more space than the solid form. So as it evaporates, pressure builds until boom.
Thats one I havent heard of. I'm going to have to try that one:D
   / Danger....Huge Alert !!!! Warning ! #17
Pour water and draino into bottom of jug, insert tinfoil so a part of it
hangs over the lip of the jugs threads and install cap so tin foil
does not fall in. If it is desturbed and mixes, kaboom.
   / Danger....Huge Alert !!!! Warning ! #18
In the old days it was carbide and water in a glass jar. I have a friend that still has a piece of glass in his eye ball.
   / Danger....Huge Alert !!!! Warning ! #20
Common in my area, Drano Bomb's, I've lost two mail boxes to them until we found out who the kids were. When the postal service investigator talked to their parents it ended, for the time being, messing with mailboxes becomes a federal offense and they got the message. Also had a road side fire I suspect was a result of one.
As a side note I heard this was developed as a way to do covert car bombs. Fact or fiction I can't say. The story I heard was, before the smaller gas filler openings a smaller bottle could be used and dropped into the gas tank of a car. Few seconds later...boom.
MarkV
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
AMCO F42B-3626CS 13ft Pull-Behind Wheel Offset Harrow Tiller (A49461)
AMCO F42B-3626CS...
WARREN POWER SYSTEMS  100KW GENERATOR (A50854)
WARREN POWER...
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
