Dang! Hydraulic fluid is pouring out of the steering unit.
   / Dang! Hydraulic fluid is pouring out of the steering unit. #1
k0ua
Epic Contributor
Branson, Mo.
Kioti DK35se Hydrostat
I was getting ready to put up the tractor yesterday and noticed something liquid on the floorboards of the tractor.. "I sure hope that is water".. I wasn't:eek::eek:
It was hydraulic fluid. I took off the covers under the steering wheel, and found fluid pouring out around the steering shaft seal on the hydraulic power steering unit. Not good. I was hoping for a loose hose fitting or busted hose.. No such luck. I called the dealer and they got it and took it with them sometime this morning. I guess time will tell what the damages will be. I know that steering unit is not cheap. And the free pickup and delivery period has passed too. It was for one year.
   / Dang! Hydraulic fluid is pouring out of the steering unit. #2
Ouch. Hopefully just a seal.
   / Dang! Hydraulic fluid is pouring out of the steering unit. #3
That's probably not good. Slightly worrisome in fact.
   / Dang! Hydraulic fluid is pouring out of the steering unit. #4
James: Bad news is that the steering unit is like $500 and the Kioti parts site doesn't show any of the internal parts. On the positive side, some of the service manuals (like the CK35 manual) show an exploded diagram of this item and it looks like there are common, replaceable seals and O-rings at the top end where the shaft goes in. So maybe a local shop (or DIY) can seal it for reasonable money.
Well I let the dealer take it. They haven't called yet. Yes, it looks like a single unit..but as you note, it does come apart, When I asked if they would try to repair it or replace it, he said they would need to see why it happened. If something "grenaded" inside, they would probably want to replace, but perhaps just an O ring gave up or something. I just don't know, I had no problems with it before it happened, and it still steered the tractor while leaking. Yes it is pretty worrisome, and definitely not a good thing.
   / Dang! Hydraulic fluid is pouring out of the steering unit. #6
I stopped looking at the DK manual too soon. The DK35 Manual does show dis-assembly of this unit, which is great if you can find parts.
   / Dang! Hydraulic fluid is pouring out of the steering unit. #7
Bad news for sure. I have no experience with this fault but am interested to hear how it all ends. Please let us know what the problem was and, if possible, how to fix it when known.
   / Dang! Hydraulic fluid is pouring out of the steering unit. #8
Likely popped an o-ring on the spool.
No progress so far... said they hope to have it out by Tommorow, and some idea of what is wrong with it. They are a pretty large and busy outfit. We will post what I know when I know it.
$354.17. The majority was labor and transport. With a replaced O ring and some replacement fluid. They said getting the unit out was time consuming. It looked like several steps in the manual. Considering transport and labor I am satisfied with the price. I should get it back Monday. I guess bad things happen to good tractors.:)
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2003 VIKING  CEMENT MIXING TRAILER (A52472)
2003 VIKING...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
2013 INTERNATIONAL MA025 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
