Damaged block installing block heater L5240
   / Damaged block installing block heater L5240
I just added the last two quarts of oil. All that is left is to reinstall the driveshaft. I am still in disbelief that it is done. It definitely took a huge step forward since joining the two halves together last Tuesday.
   / Damaged block installing block heater L5240 #432
It's been a fun and informative ride.
Nice work!!! :thumbsup::thumbsup:
I was thinking about installing a block heater in my L2800. I might just keep on thinking about it. Glad to hear it is running again.
Bring it on over. We'll have that engine rebuilt, um..... I mean block heater installed in time for winter!
   / Damaged block installing block heater L5240 #434
So, will you leave the snow chains on for winter since it's coming up soon? :D
   / Damaged block installing block heater L5240 #436
   / Damaged block installing block heater L5240 #437
Glad that everything is back together and seems to be working well.
You did it the right way each and every time there was the temptation to take the easy / quick way out.
Your patience is inspiring.
You know.. I only got to use the tractor once with them on. They are coming off tonight as my son drives it out of the garage. I won't need them again until December..
   / Damaged block installing block heater L5240 #439
Congrats!!!! Happy to see it back in action. ����
Got any leftover parts? ��
Just a few fender bolts that did not want to go back into the deck. I also misplaced one of the bolts that holds the antifreeze overflow tank on. Hopefully I won't find anything "important" when I start picking up all of my tools!:thumbdown:
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A56436)
2023 Kubota U48-5...
2020 DRAGON ESP...
2018 CATERPILLAR 323 EXCAVATOR (A60429)
2018 CATERPILLAR...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
Case Axial-Flow Combine Wheels NO RESERVE (A56436)
Case Axial-Flow...
