Damaged block installing block heater L5240
   / Damaged block installing block heater L5240
Well done Adiredneck! Your 'adventure' has caused me to check this forum everyday for an update on your progress. While I will genuinely miss this thread, I'm sure you will not
Stay tuned... This winter I am tearing down the rearend on my L3400. Dealer says the howl is completely normal when you engage the brakes, but I call BS. It might be considered "chatter" from what I have read.
I will not be using a Dewalt drill on that project in case anyone is wondering....
   / Damaged block installing block heater L5240 #452
If it would make you feel better I can loan you a Milwaukee drill... I have appreciated your sense of humor through out all of this. I don't think I could be quite so gracious. I also like the fact that you say that your wife has been real supportive through all of this. That says a lot for your wife and your relationship.
I put two hours on the engine and I am happy to report that all is well.
I stopped by the dealer and had them print out all of my invoices.
Wsm. $137.00
Piston. $168.41
Two sets of rings. $84.20x2= 168.40
Crank bearings. 4 @ $27.71= 110.84
Rod bearings 4 @ $18.80 = 75.20
Front main bearing $ 46.81 (one piece bearing that I had the machine shop install)
Upper gasket set. $126.28
Lower gasket set. $ 159.03
Driveshaft output seal. $ $5.30
Kubota gray paint 2@$12.80 = $25.60
O-ring for hydraulic pump. $ .70
Transmission input shaft seal. $ 11.10
Input shaft seal gasket. $ 5.36
Machine shop cost: $ 420.00
Wix oil filter$ $8.20
Wix fuel filter $ 12.65
Shell Rotella 15w-40: 3@18.00= $54.00
Grand total: $1534.88.
I did purchase a few tools, like a 3/4" socket set, 3 jaw puller set (didn't use any of them). There were also the bolts that I had to purchase because I stretched the original ones, plus the 2nd rear main seal that we messed up.
All in all, not bad!
   / Damaged block installing block heater L5240 #456
After the commonality of the struggle, you will own that tractor forever.
   / Damaged block installing block heater L5240 #457
For some reason, when I own something, it seems like I have to work on it, but a knuckle or two, cuss at it, then it feels like its mine. You can without a doubt say you OWN this tractor. Congrats on getting it fixed and going again.
I checked again last night and I see another oil drip forming on the clutch drain. Not pleased. I am trying not to get too worked up about it. I still have a hunch that the front axle pinion seal is the culprit and that the oil is running down the driveshaft cover into the clutch housing.
Last year, I had oil dripping from the driveshaft cover and in the clutch housing. I monitored all oil regularly, and the only place I lost oil/fluid was in the front axle. It was regularly 2+ quarts low. I never saw oil drip anywhere on the axle seals. Just on the outside of the driveshaft and in the clutch housing.
Whenever I would check it, the fill plug would hiss as if it had built up a few pounds of pressure. Fingers crossed that this is my problem. My first order of business is to take the plug out, and drill & tap for 1/8" NPT. I'll put a 90deg hose barb and vent up into the engine compartment to see if that helps.
   / Damaged block installing block heater L5240 #459
Drill??
Again????
:confused2:
:stirthepot:
:D
:laughing:
Drill?? Again???? :confused2: :stirthepot: :D :laughing:
I had a hard time not making a comment when I wrote that! If you notice, I wrote "take the plug out and drill & tap". Just think, if I had only removed the frost plug BEFORE I drilled through it, how much easier my project would have been!
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
