Damaged block installing block heater L5240
   / Damaged block installing block heater L5240 #421
Don't fill the oil filter unless the actual oil pump is fully primed!
Pull the oil filter and crank it over a bit to get oil to the filter housing, like I said before if you pull a vacuum on the outer ring of the oil filter housing you'll only crank it over just a few seconds, install the oil filter and good to go.
Oil flow is going from outer ring of housing through the oil filter and leaving the filer through the center threaded hole.
Two guys required and have something ready to kill the air to the intake if something gets out of hand.
Good luck, Fred
Don't fill the oil filter unless the actual oil pump is fully primed! Pull the oil filter and crank it over a bit to get oil to the filter housing, like I said before if you pull a vacuum on the outer ring of the oil filter housing you'll only crank it over just a few seconds, install the oil filter and good to go. Oil flow is going from outer ring of housing through the oil filter and leaving the filer through the center threaded hole. Two guys required and have something ready to kill the air to the intake if something gets out of hand. Good luck, Fred
I get pulling the filter off, cranking until oil squirts out, but how would I put a vacuum around the outside ring of the filter housing?
Although tempted to try it now by myself, tomorrow is now the day when my help will be here. I have the air intake hose off ready to starve it out if we have a runaway.
   / Damaged block installing block heater L5240 #423
Just use a shop vacuum over the filter housing. Yes it can make a mess.
You could cut off a clear plastic soda bottle as an adapter.
Regards
IT Lives! Once I figure out how to post a video from my phone, I will!. It runs just as smooth as it did when I bought it.
Time to put the cosmetics on now.
   / Damaged block installing block heater L5240 #425
Awesome! Glad you took time to repair it right and take care of other issues along the way. Thanks much for sharing your journey, especially that first costly mistake.
   / Damaged block installing block heater L5240 #426
I was thinking about installing a block heater in my L2800. I might just keep on thinking about it. Glad to hear it is running again.
   / Damaged block installing block heater L5240 #427
Congratulations... :thumbsup: :cool2: :drink: :cloud9:
   / Damaged block installing block heater L5240 #428
You are my hero! :thumbsup::drink:
   / Damaged block installing block heater L5240 #429
Congrats!!! Been following this since jump street. Glad it worked out!!
   / Damaged block installing block heater L5240 #430
Great news, I've been following along from the beginning, what a long haul.:thumbsup::thumbsup:
2003 IC Corporation 3000IC School Bus (A59230)
2003 IC...
JOHN DEERE 6145R TRACTOR (A59823)
JOHN DEERE 6145R...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2008 HINO 26FT NON CDL BOX TRUCK (A59575)
2008 HINO 26FT NON...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2024 ArmorLite Aluminum End Dump Trailer (A56438)
2024 ArmorLite...
