Damaged block installing block heater L5240
   / Damaged block installing block heater L5240 #392
I don't think it would be hard to make a set up to test the calibration of your torque wrenches at home.
If you have a known weight, and a lever arm of a known length, you could hang the weight from one end of that lever arm and use your torque wrench at l the other end of the lever to see at what setting it clicks at.
For example, 50 pounds hanging from a bar two feet long would start to move when 100 pound feet were applied at the other end.
Bill
   / Damaged block installing block heater L5240 #393
Did you get it running?
Bolts arrived last Wednesday. Crazy weekend with a scout camp out. I went out yesterday afternoon and finished up the rear main housing. I cleaned and mounted the flywheel. My neighbor held a pry bar on the flywheel so I could torque it. I cleaned and mounted the clutch last night. I do not have a clutch centering tool, but I am fairly confident that I have it close enough to go back together. Zero issues. Tomorrow night, dad is coming over to join the two halves together. My neighbor said he would help also. I think we'll want his help. If I can get this accomplished tomorrow, I can finish the rest by myself this week. I so badly want to get it running this weekend.
   / Damaged block installing block heater L5240 #395
Good Luck dude, you have been a very patient man!
   / Damaged block installing block heater L5240 #396
Good luck. I'm sure you can't wait to hear it fire up.
   / Damaged block installing block heater L5240 #397
I used a deep socket (10mm I think) that fit into the pilot bushing. I did have to add some tape to the larger part so the splined disk was somewhat tight, worked perfectly. Others have used dowels or whittled down broom handles. I have a post here somewhere with pictures.
I hope it goes back together easily for you.
   / Damaged block installing block heater L5240 #398
I did the same with a socket and some tape. Worked fine.
Well. She's back together now. Wasn't too bad. We ended up spinning the crank over to get the splines to match up. A little jiggling and it went right together. I worked until 9:45 tonight. Mounted the fuel tank, steering wheel and controls, started on the wiring harness.
Here she is. So happy to be able to move forward.
2014 Lincoln MKS Sedan (A59231)
2014 Lincoln MKS...
Schulte XH1500 Series 4 Pull-Behind Batwing Rotary Brush Cutter Tractor Attachment (A59228)
Schulte XH1500...
2004 AGCO Gleaner 3000 Corn Header (A56438)
2004 AGCO Gleaner...
Booster Cables (A59230)
Booster Cables...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
