Dale Phillips
/ Dale Phillips #1
swinn
I am planning a purchase of a Mahindra 6000 or 5005 tractor and some Dale Phillips Equipment including a 6' shredder with slip clutch. Any reviews or opinions about Dale Phillips equipment or the tractor I am considering? Thanks.
/ Dale Phillips #2
Is this from Bill's Tractor in Texas?
Have you considered any 4WD units?
How many acres do you want to work and is the bulk of the work brush hogging?
/ Dale Phillips
i am not Bill's tractor but I am considering making the purchase from his dealership. I live on 30 acres and shredding would be a large part of the work but I plan to use it to clean up and plant lease pastures in time. I haven't really considered the 4-wd due to the cost and the thought the bigger 2-wd would prove more usefull on the bigger places. I am considering the 6000 model or the 5005 model with a loader. What due you think? Thank you very much for your time.
/ Dale Phillips #4
Mr. Swinn,
Give me a dollar figure, your budget is allowing you to spend and the list of items you expect to buy for that money, then I can give you a better answer...
Right off the bat, {I'll explain in detail later} those transmissions offered on those two Mahindra's are very dated {sliding gear} and work very poor with a loader {back & forth shuttle}. Unless they have changed the hydraulics to dual/separate pumps, you may also have borderline hydraulic flow and pressure for decent loader work...
You must remember these designs have been around since the late 50's/early 60's and really haven't been upgraded that much since...
Anyways, I'll wait for your response and go from there...
I just have a feeling, you can get something else much better with a little compromising for about the same dollars you plan on spending... {especially if you have your heart set on a loader... I really feel you'd be disappointed with this combination you've potentially selected.}
/ Dale Phillips #5
swinn,
The Mahindra 5005 is available from Delta Tractor in Batesville, MS for $12750.00
and
the Mihandra 5005DI (not sure if the different model number indicates differences in the tractor) from Knox Tractor in Houston.TX for $11950.00
Neither offer the 6000 on their websites.
How does this compare to your pricing? Does "Bill's" have a website?
/ Dale Phillips
My top price is around $17,000. That would include the tractor and maybe loader, 6' shredder(not light), 6' box blade, 6' rock rake. I'll add more equipmnt later as I need it. Bottom line I would like to get the most I can for up to $17,000. The price from Knox matches the best I have found. I have looked a billstractor.com and topflightequipment.com. There is also a place near Ft. Worth, E&E Equipment, that can give a price in that range. I really appreciate. This is the help I was hoping to find.
2018 Nissan Pathfinder SUV (A64557)
2018 Nissan...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
Kinze Planter Tire (A65640)
Kinze Planter Tire...
Cherry Picker (A65640)
John Deer MX8 Bush Hog, 3pt, Dual Gear Box, PTO (A62679)
John Deer MX8 Bush...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
