dad drove 3 hours to buy a jd 535 baler came home with a 567.
   / dad drove 3 hours to buy a jd 535 baler came home with a 567. #41
Not to be a a-- but that is why you take time to pm your equipment grease, oil , fuel, and blow things off we have never knock on wood had a problem like that. I'm sure it can happen butt we have had oiler on last two balers and no problem. Just make sure you keep dust cleaned out an don't let it build up
Yep. Small gas powered quincy air compressor is 1 of thebest investments I have made
   / dad drove 3 hours to buy a jd 535 baler came home with a 567. #43
If your baling sandy soils, sand will get everywhere and premature wear. No way around it. Yes, if you keep the chain oiled, it will attract and hold sand, but if just WD-40, it will just get pulverized or fall off.
Here's the deal between the O-ring and non O-ring, A chain wears more from the inside if non Oring and it will stretch. This stretching is what wears out your sprockets because a stretched chain no longer fits. I would say an Oring chain will last at least twice as long in a sandy environment. Now you have to decide if your labor, trip to the store, shipping whatever is worth it. If you have a long off season with nothing to do, go the cheap route. Some people get a whole bunch of bales on standard chain. But sand changes everything.
   / dad drove 3 hours to buy a jd 535 baler came home with a 567. #44
Under my best assumption you are talking about roller chain correct. With chain stretch shoot not suppose to tighten chain where it is muscled tight anyway that's hard on bearings etc. if any are around and in most cases there are. Not to mention shafts as well that is here common sense comes into play
   / dad drove 3 hours to buy a jd 535 baler came home with a 567. #45
Checked out the o-ring chain see but wow why not just run a normal chain and give the machine the attention that it needs when it needs it and go on. Wear items will always wear just need maintained.
   / dad drove 3 hours to buy a jd 535 baler came home with a 567. #46
Kyle
Are you implying o-ring chain will last at least 4 times longer as regular chain. O-ring seal lubrication won't keep the rollers from wearing on sprockets. Will o-ring lubrication keep chain cooler? The chains on a JD rd baler will get "HOT" even with motorcycle chain lube applied.
How much do all the sprockets cost?
   / dad drove 3 hours to buy a jd 535 baler came home with a 567. #47
I realize chain stretch(wear in pins & rollers) wears on sprockets but so does heat and just plain ole use. Then one throws in the sandy soil where I live and it would interesting to see if o-ring chains are worth the extra cost. Yes I know sprockets are high but what isn't??
56" FRONT BLADE (A52708)
56" FRONT BLADE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56438)
Ditch Witch 6510A...
2013 Ford E-350 Cargo Van (A56858)
2013 Ford E-350...
New/Unused Portable Toilet/Shower (A57453)
New/Unused...
