Jul 17, 2007 / DA cylinders #1 T tlbuser Veteran Member Joined Jul 15, 2005 Messages 1,307 Location lower part of Md. Tractor JD310, ASV RC-100 What's the possibility of using DA cylinders with a single acting 12v pump? Can you just vent (to tank) the unused side?
Jul 17, 2007 / DA cylinders #2 kennyd Advertiser Joined Jul 6, 2003 Messages 13,843 Location Westminster, MD Tractor John Deere 3720 CAB/TLB, JD455 Yup! The unused port can be vented, or often there is a hose that runs from that port to the top of the tank just to keep the system "sealed"
Jul 17, 2007 / DA cylinders #3 JerryG Super Member Joined Apr 6, 2000 Messages 7,356 Location Northwest Arkansas Tractor MF 1440-4 PowerShuttle There is a screened vent that screws in the port that you can buy. Any hydraulics store or dealer should have them.
Jul 17, 2007 / DA cylinders #4 Soundguy Old Timer Joined Mar 11, 2002 Messages 52,424 Location Central florida Tractor RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC And with the correct valve and plumbing.. you can use it DA... Soundguy
Jul 17, 2007 / DA cylinders Thread Starter #5 OP T tlbuser Veteran Member Joined Jul 15, 2005 Messages 1,307 Location lower part of Md. Tractor JD310, ASV RC-100 Thanks guys
