D3/931 backhoe
/ D3/931 backhoe #1
dynasim
Platinum Member
Manhattan, Kansas
NH TC45D
I am interested in installing a D3/931 backhoe onto a farm tractor. Does anyone know what its weight(the hoe itself) and reach are? It is a ways away, and I would like to know if it is a wild goose chase before I go.
I have looked many different place, but can't find any info. I think they are late 80s vintage.
Chris
/ D3/931 backhoe #2
I have a D3B and the service manual covers the D3B/931B backhoe, which I suspect is similar to the one you know about. The weights of the different parts (boom, stick, etc.) are scattered through the manual. I did a quick add-up and got to about 4,000 pounds without the frame that is permanently attached to the tractor. The side shift frame adds another 1500 pounds.
That weight of 4,000 pounds seems about right. I have a JD 455D with a JD 9300 backhoe that the manual says weighs 2,983 pounds without the bucket or mounting bracket. The Cat backhoe is probably a bit heavier.
It does not give the digging specs for the Cat, but the JD backhoe will dig 13'8" deep.
The 3,000# model 9300 backhoe is a full load for the 15,000 pound 455D crawler loader, and going up a hill the front end of the crawler (with the bucker) will lift off the ground. The center of gravity of the backhoe is probably four feet behind the mounting point when folded up. I realize you will not use a three point hitch, but in general it seems to me that a tractor would need a TPH lift capacity of at least 8,000-10,000 pounds in order for the axles, bearings, etc. to carry such a backhoe successfully.
/ D3/931 backhoe #3
There are 2 models of the D3 with a hoe around this area. One significant design feature of that implement is the distance or length of the hoe that extends rearward of the crawler.
Gotta be 3 - 3 1/2 feet to the base of the boom... at least. The center of gravity would be a real consideration for any machine and mounted on a tractor would be a major challange to keep the front end from wandering all over the map!
AKfish
/ D3/931 backhoe
Wow, that is heavy.
I was thinking about installing one on a farm tractor that weighs about 10k. Don't think that will work.
There is one on ebay that looks like it is in really good shape for $1500. Even for cylinder salvage, that would be a good deal. It is in CO.
Thanks. You saved me a couple hundred bucks in gas.
Chris
