d1850fd
   / d1850fd #1
mit
any expert out there knows if a mitsubishi d1850fd tractor has an equivalent.i heard that satoh tractors were made by mitsubishi. so there may be a model satoh with the same make up like d1850fd.:confused:
   / d1850fd #2
Mit,
Go to Valley Power, click on the technical data link on the left. You will find a wealth of information compiled by Mr. Ed Krampitz that may answer some questions. It has helped me as well as many others.
   / d1850fd #3
The closest US model is the S670. I have parts books & supply parts using the D1850 parts book. The ST4820/1840 is the Satoh equivalent.
   / d1850fd
just got this tractor delivered today.it started and ran fine.then the starter switch started acting up.u have to put your hand behind the switch for it to work. while it is running i cant get the 3 point hitch to go up. i work the 3 point lever and nothing happens. help please.
   / d1850fd #5
Did you make sure the 3pt knob under the ft. of the seat is open and there is hydraulic fluid in the tractor.
   / d1850fd
i did not check the fluid level. the valve is midway.i do not know which way is on.the seller said that it has fluid he changed before shipping.it has jd 20 hydralic oil.he also has a quick connect in the hydralic line.it looks like it is connected.:confused:
   / d1850fd
fluid level is ok. any suggestions?
   / d1850fd
any one knows what oil to use in this tractor?
hydralic
engine
transmission
differential
   / d1850fd
what does it mean when a diesel engine give off blue smoke? not heavy but bearly visible if running in a shaded area.:confused:
   / d1850fd
anyone have a kpx backhoe attached to their tractor. what is your opinion of it?the price seems reasonable.
   / d1850fd #11
Mit,
I use 15W40 chevron diesel rated oil in the engine. Rotella is good too. Whatever you used make sure it if for a diesel engine. My transmission and differential has common reservoir on both my tractors. (smaller than yours) If you are going to use a backhoe, loader or other hydraulic stuff and your 1850 has a common reservoir then you can use hydraulic oil rated for gear drive transmissions. It is available at Tractor Supply, Wal Mart, parts stores etc.. I buy mine in 5 gallon pails and it says what it is for on the bucket. It usually gives a list of brands it will be compatible with. Look for one compatible with JD 303. (pretty common). Both my tractors puff a little smoke, not much.
   / d1850fd
thank u much for advices.i really appreciate. this is my first diesel tractor.learning something new every day.:)
   / d1850fd
with the loader attached now i have to recheck the oil in the hydralic case.there is no dip stick. what do i do?
   / d1850fd #14
There should be a check plug on the side of the trans/rear end case. On my tractors it just looks like a bolt that has nothing attached to it. Put the oil in the top and when you see it running out the side, your done. It's a little messy but if you are just topping off that how it is done.
   / d1850fd
can u put up a pic. i looked and found a nut on the clutch side. i found the oil rotella 15w40 at auto barn. 12 dollar gal. i found trans/hyd oil at john deere dealer 58 dollar for 5 gal bucket.
   / d1850fd #16
Can't post a pic cause I don't have the same tractor as yours but generally they work similar. Try other sources for the transmission/hydraulic oil. Check with Tractor Supply, Wal Mart, etc. Per other posts on TBN they have it. 58 is too high for trans/hydr. oil. Think I saw it for $30.00 at TSC 3 days ago.
   / d1850fd #17
You have a level plug on the right side of the transmission behind, and about on the same level as, the differential lock pedal. Send me an email and I'll send a photo with its location. Better yet, consider buying a operators/maintenance manual from me. Bill - satohparts.com
   / d1850fd
there is another plug on the other side near to the clutch.what is that one for? i saw the one u spoke about it is just above the filter screen access.
   / d1850fd
what is that bar thing that is near that plug bolt.looks like some kind of brake lever.what do u use it for?hey oliver i put up some pics does it look like yours?
   / d1850fd #20
I'll have to look at mine. Is the plug on the clutch side at the same level as the plug on the brake side? The brake side plug looks lower.
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
Deere 310L (A53317)
Deere 310L (A53317)
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
Deere 35G (A53317)
Deere 35G (A53317)
