D140 Will Not Start
/ D140 Will Not Start #1
Hyponychial
John Deere
Got on my 2013 D140, turned the key, and nothing. No solenoid clicking, no starter turning, nothing. Battery voltage reads 12.7V. Voltage from battery+ to starter mounting bolt (starter ground I am assuming) is 12.7V. Jump the starter solenoid between two main lugs, nothing. Jump from battery+ to starter+, nothing. Replaced solenoid on advice from JD dealer, still nothing. Could it be the starter or something else?
/ D140 Will Not Start #2
When you jumped across the starter directly, were you using a different battery? If so, and it was a known good battery it sure sounds like a bad starter.
Other items to consider are bad connections on the battery and ground strap. A high resistance connection will still show voltage on a meter, but will fall to carry any current (amps). Also, a battery can fail and still read 12.x volts with no load. A load test will confirm a good battery.
/ D140 Will Not Start #3
Check to see if there is a fuse off the battery side of starter solenoid and its good, it powers ignition switch and relays, starting circuits...
/ D140 Will Not Start #4
If you are jumping the big lugs of the solenoid and get nothing, that takes the solenoid, fuse and the switches out of the equation. That leaves the battery, starter, cable in between, ground or an engine that won't turn.
So to start with, try and turn the engine via the screen on top.
2022 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2022 FREIGHTLINER...
2021 ASV RT-120 FORESTRY SKID STEER (A65053)
2021 ASV RT-120...
2018 Case 580N EP 4x4 Loader Backhoe (A64553)
2018 Case 580N EP...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
Cattle Feeder (A65640)
