Cylinder seal repair
   / Cylinder seal repair #1
scott854
PA
Case 680E
I recently purchased a Case 680E. It works fine, but has some hydraulic leaks. One is the seal on the loader lift cylinder. I pulled it and am attempting to remove the rod. I removed hoses and nut and am attempting to pull out the rod, but it won't move. The cylinder worked fine on the loader 30 minutes prior to removal. I attempted to pull it out with a cumberlong, but no progress. Any suggestions?
   / Cylinder seal repair #2
Not knowing exactly what you mean I have to ask what may be fairly simple questions first. In what way are you trying to remove the rod? Did you remove the gland nut already? Or is the rod just not moving in the cylinder without hydraulic force? Is the rod bent keeping it from being able to move in the cylinder with the gland still in place?
Brian
Gland nut is removed. The rod does not appear to be bent when used on loader. I am attempting to pull the rod out ot repair the seals.
   / Cylinder seal repair #4
Hmmmm, normally a come-along would do the trick. I've used air pressure in cases like this, but one has to be careful. Even as heavy as those rods are they have no problem becoming high speed projectiles. Ask me how I know, lol.
Brian
I don't really want to try the air pressure...I will take your word for it. Maybe I will hook the hoses back up and push it out with hydraulic fluid.
   / Cylinder seal repair #6
I've done that too, in places where the hydraulic oil mess wasn't gonna get me in trouble.
   / Cylinder seal repair #7
I am not old enough yet to use air pressure on any cylinder strip job!
Use low volume hi-press power pack and force it out slowly over a bucket to catch the spill.
Try to bleed out most of the air before pressurising.
   / Cylinder seal repair #8
Scott,
the case piston consists of two sets of v packing with a plastic machined spacer.....what you are experiencing is the plastic spacer under usage gets swollen in the hyd oil over time
When you get a new seal kit it "should" come with the v pkg piston set with this new spacer as part of the kit......if they don't come with the kit you can turn them on a lathe and take off about .010 to .015" off the dia......second thought if someone tries to sell you a kit without that whole set (w/o the spacer), then they prolly have the wrong parts....those case piston sets are made specifically for case
use a comealong to remove rod assy, it will come easier than you think....if you resort to banging it out with a BFH (big friggin hammer) use a junk bar in the eye and don't hit the rod accidently
Do not use air pressure unless you have your insurance paid up in full (life and/or health)
   / Cylinder seal repair #9
Thanks for the help. I tried a come-along without success, but the hydraulic power pack worked great (and 1.5 gal of hydraulic fluid). BFH and wood block was needed to get the gland nut all the way off.
Thanks againfor your help.
CATERPILLAR D6T XL CRAWLER DOZER (A52705)
CATERPILLAR D6T XL...
2013 Ford F150 4X4 Pickup Truck (A53422)
2013 Ford F150 4X4...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
2014 Nissan Juke (A55758)
2014 Nissan Juke...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
