cylinder question
/ cylinder question #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
i have to replace a cylinder on my backhoe ...overall lenght is 21'' retracted...extended shaft is 16'' does this make it a 16'' stroke ??? i know it should be simple .but it must my old age creeping in..i just cant think straight.... thanks for the help bruce
/ cylinder question #2
With cylinder retracted, measure the distance from center of base mounting hole to shaft end mounting hole. Then extend the cylinder shaft until it stops. Measure from the center of the base pin to the center of the pin hole on the extended shaft. That will be your stroke.
/ cylinder question #3
I thought you were supposed to subtract the retracted length from center of pin to pin from the extended length from center of pin to pin to get the amount of stroke. So if extended length is 60" from center to center and retracted is 44" from center to center, then the stroke would be 16".
/ cylinder question #4
We are saying the same thing.
/ cylinder question
thanks for the replys... i understand now,..thanks for all your help
2015 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2015 WINSTON...
2007 OK TRUCK & TRAILER PRESSURE WASHER TRAILER (INOPERABLE) (A67714)
2007 OK TRUCK &...
PORTA POTTY (A67714)
2001 VIBROMAX W1106PD ROLLER (A66091)
2001 VIBROMAX...
2006 JOHN DEERE 444J WHEEL LOADER (A67714)
2006 JOHN DEERE...
2014 GULF STREAM TRAILMASTER (A67714)
2014 GULF STREAM...
