cylinder question
/ cylinder question #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
i have to replace a cylinder on my backhoe ...overall lenght is 21'' retracted...extended shaft is 16'' does this make it a 16'' stroke ??? i know it should be simple .but it must my old age creeping in..i just cant think straight.... thanks for the help bruce
/ cylinder question #2
With cylinder retracted, measure the distance from center of base mounting hole to shaft end mounting hole. Then extend the cylinder shaft until it stops. Measure from the center of the base pin to the center of the pin hole on the extended shaft. That will be your stroke.
/ cylinder question #3
I thought you were supposed to subtract the retracted length from center of pin to pin from the extended length from center of pin to pin to get the amount of stroke. So if extended length is 60" from center to center and retracted is 44" from center to center, then the stroke would be 16".
/ cylinder question #4
We are saying the same thing.
/ cylinder question
thanks for the replys... i understand now,..thanks for all your help
2017 CATERPILLAR 335FL CR EXCAVATOR (A65056)
2017 CATERPILLAR...
2009 IC Corporation PB105 School Bus (A68183)
2009 IC...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2012 MACK CHU613 (A67714)
2012 MACK CHU613...
