Cylinder Length
/ Cylinder Length #1
Ground Control
2020 Kubota B2601
Have a cylinder related question. Does anyone know the availability of an extension that screws onto the end threads of the piston rod, and accepts the clevis (yoke) at the end. I need about a 1" longer push (w/o changing cylinders).
/ Cylinder Length #2
What size shaft and what is on the end of your cyl now? I have 2 or 3 what state are you in?
/ Cylinder Length #3
One inch longer on extend is gonna result in one inch shorter retracted as well with the same cylinder. Is that acceptable?
Got any pics of the cylinder? Alot of cylinders usually have a generous amount of thread on the rod. Sometimes you can just unscrew the clevis/yoke to gain the inch.....Lots of the thread on clevises and yokes have a set screw or lock bolt to hold the position you put it in.
Is there also a possibility of re-locating the base end mount? Again, pics would help here as would application
